SpeedFan
Magical Pineapples
https://linustechtips.com/topic/597094-fan-control-software/#findComment-7755053
3 minutes ago, Jskn said:
would I be able to make a custom fan curve because it does not say anything in the intro about that
You can create custom fans curves, go check about Jaytwocent newest video.
Magical Pineapples
https://linustechtips.com/topic/597094-fan-control-software/#findComment-7755083
HWInfo Allows you to control the FAN Speed + custom fan Speed During Different temperature. But it depends on your laptop model that if its gonna work or not.
Ryzen 5 3600 | MSI B450 Tomahawk Max | Corsair Vengeance lpx 32gb 3600mhz | EVGA GeForce RTX 3080 FTW3 ULTRA GAMING | XPG Core Reactor 850w
https://linustechtips.com/topic/597094-fan-control-software/#findComment-7757992
