1080p build. Thoughts ?
Go to solution Solved by Lotus,
You spend way, WAY too much on the motherboard, and that PSU is not worthy of the other parts. I'd get this:
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($244.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.89 @ OutletPC)
Motherboard: Asus Z170-E ATX LGA1151 Motherboard  ($88.98 @ Newegg)
Memory: G.Skill NT Series 8GB (2 x 4GB) DDR4-2400 Memory  ($31.98 @ Newegg)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  ($287.10 @ Newegg)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($61.99 @ SuperBiiz)
Total: $726.93
Generated by PCPartPicker 2016-05-15 11:22 EDT-0400
I need advice. Is this a good build for 1080p gaming? And for future games.
Bugdet: 700$
GPU: Gtx 780 (I got it cheap for 150$)
CPU: i5-4690k (220$)
Motherboard: Asus Maximus VII Hero (240$)
RAM: 16 gb Kingston HyperX Fury (60$)
PSU: Corsair CX 600w (I already have it from a previous build)
I also have a case and harddrive.
Can you recommend anything else? Or is this fine.
Thanks.
https://linustechtips.com/topic/596353-1080p-build-thoughts/
Everything looks good except that PSU.
Intel Core i7 7770K | 32 GB's Ram 3000MHz | GTX 1080 Ti | 250GB SSD | 3TB 7400 RPM | Sound Blaster Z | ASUS ROG MG278Q | Razer Blackwidow Chroma | Final Mouse 2015 | Blue Yeti | Seinheiser HD 600's | Beyerdynamic DT 990 Pro | Aune T1 MK2
https://linustechtips.com/topic/596353-1080p-build-thoughts/#findComment-7747801
Total: $726.93
https://linustechtips.com/topic/596353-1080p-build-thoughts/#findComment-7747808
The mobo might be overkill, but that's a matter of opinion on my part. There are much more affordable Z97 boards out there that would do you about as well.
The PSU has got to go. CX series PSUs have some serious performance issues. If you like Corsair PSUs, the RM650 and RM650i are both great, but they come at a premium. EVGA, XFX and Seasonic PSUs are solid choices as well.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/596353-1080p-build-thoughts/#findComment-7747811
2 minutes ago, Emil Busk said:
Should i not go for that 16 gb of ram. And go for a better PSU then? I already have some old ram with 8gb
I would go with @Lotus 's build.
https://linustechtips.com/topic/596353-1080p-build-thoughts/#findComment-7747826
4 minutes ago, Emil Busk said:
PCPartPicker part list: http://pcpartpicker.com/p/JWVXmG
Price breakdown by merchant: http://pcpartpicker.com/p/JWVXmG/by_merchant/
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  ($297.89 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.49 @ Amazon)
Motherboard: Gigabyte G1.Sniper B7 ATX LGA1151 Motherboard  ($92.98 @ Newegg)
Memory: G.Skill NT Series 16GB (2 x 8GB) DDR4-2400 Memory  ($53.99 @ Newegg)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive  ($56.00 @ NCIX US)
Total: $530.35
Generated by PCPartPicker 2016-05-15 11:28 EDT-0400
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
https://linustechtips.com/topic/596353-1080p-build-thoughts/#findComment-7747831
Ive had that PSU for over 15 months now. U should NOT get such an expensive mobo when u building a budget build. Get Asus Z97-A or something in that price range. U can change PSU for EVGA or Seasonic S12II
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
https://linustechtips.com/topic/596353-1080p-build-thoughts/#findComment-7747834
Total: $726.93
He already has that 780, so suggesting other GPU makes no sense.
https://linustechtips.com/topic/596353-1080p-build-thoughts/#findComment-7747839
Bugdet: 700$
Thanks.
motherboard is overkill. change the psu.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/596353-1080p-build-thoughts/#findComment-7747847
