I've have had water cooling for quite some time now but have noticed that my Northbridge seems to get very hot. I have seen some youtubers with water blocks on that section of the MB to provide cooling to it seeing at how hot it can get. My case doesn't have the best cooling since I have it mostly set for silence so I really don't want that part to over heat one day. I want to know if any of these universal parts will fit my MB or if anyone has any recommendations.
MB = Biostar TS970 AM3+ socket
Universal Blocks  for northbridge:
http://koolance.com/index.php?route=product/category&path=29_66
This site has 3 universal blocks but idk much about the northbridge so yea.
Thank you for taking the time to read this let me know if I am missing anything.
https://linustechtips.com/topic/595981-northbridge-water-block/
6 minutes ago, AngelicBeatz said:
-SNIP-
In most cases it doesn't need it but if you want to integrate it into your loop just measure out the mounting points of that heatsink and find a universal block that can span those mounting points.
https://linustechtips.com/topic/595981-northbridge-water-block/#findComment-7744342
Doubt there is an official chipset waterblock for that motherboard, so finding a universal block would be your best option (might take a bit of macgyvering). In most cases the chipset wont get warm enough to cause harm even with poor airflow, so I wouldn't bother...
The chipset on my Z77 sabertooth is also quite hot to the touch, but the heatsinks would be designed well enough to ensure they dont overheat...
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/595981-northbridge-water-block/#findComment-7744408
Thank you both for your help I will be doing that later tonight I am dealing with an HP laptop that is just being a bitch.
https://linustechtips.com/topic/595981-northbridge-water-block/#findComment-7744528
