As I've been using my secondary PC for 4 days, when I first plugged in my g402 into my second PC, with the same windows settings (6/11) at the same DPI settings of 400 but it feels soooo much slower than what it was used to on my main :P, it was a easy fix as all I had to do was turn my dpi upto 800 and it was exactly the same (obviously turning my in-game sens in CS down to 1.07) so any ideas why although at the same settings, it was like half as slow? It's okay now but still, it's good to know why for no reason it's at half the speed...
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/595027-weird-mouse-issue/
Just now, GreezyJeezy said:
Is the monitor different?
same two monitors, one 1080p 120hz and one 60hz 1050p :P
https://linustechtips.com/topic/595027-weird-mouse-issue/#findComment-7734693
Just now, AstroBenny said:
Are you using a different screen resolution?
Why don't you actually measure the distance for a 360 degree turn on your mouse pad with both PC's. and compare.
In game it's the exact same, it's more the fact that when on my desktop and browsing ect. it's half as fast :( (as there's a reason I'm using my second PC...no motherboard in main or CPU or RAM right now...sold the RAM and CPU while the motherboard is getting RMAed...motherboard fucked itself up so took it as a chance to upgrade...)
https://linustechtips.com/topic/595027-weird-mouse-issue/#findComment-7734708
