Fans CONSTANTLY ramping :(
19eightysix
I've tried playing with the fan curve in AI suite (don't get me started on this garbage program) but my fans are CONSTANTLY ramping and its bloody annoying.
I've got 5 Coolermaster sickleflows currently, 2 intake 3 exhaust. I've done the AI suite setup for them, I've played with the fans curves I'm all out of ideas aside from just going external fan controller. Figured I'd ask before spending more money from the watercooling fund.
CPU-Intel I7 6700k
Motherboard-Asus Maximus Formula VIII
Memory-16g GSkill Ripjaws V series 3200mhz
Graphics-Asus Strix 980ti OC
Power-Corsair HX750i
Storage-256g Samsung 950 Pro, 500g Samsung 850 Evo, 1tb Hitachi 7200rpm
Case-Phanteks Eclipse p400 Anthracite Grey
Are they ramping up alongside your temps or randomly?
First, are those PWM fans? Second, are you using the BIOS fan profiles?  It works really well on my Asus motherboard using Noctua PWM fans.
i7 4790k @4.7 | GTX 1070 Strix | Z97 Sabertooth | 32GB  DDR3 2400 mhz | Intel 750 SSD | Define R5 | Corsair K70 | Steel Series Rival | XB271, 1440p, IPS, 165hz | 5.1 Surround
PC Build
Desk Build
what's the fan curve like? is it steep at where your processor's temps fluctuates at?
whats the spin up and down delay?
-sigh- feeling like I'm being too negative lately
almost seems random they ramp up during gaming as expected but once i stop gaming i have to open ai suite and turn the fans to silent mode several times before they will shut down
CPU-Intel I7 6700k
fan curve is 40 to 60 degrees its at 600-800 rpm then at 70 its boosts to 2000rpm
they are 3 pin fans
CPU-Intel I7 6700k
You're probably forcing them to do something they aren't supposed to do.
Looking at Cooler Master's site SickleFlow fans have either a fixed RPM or a -/+ 10% off of labeled RPM.
They're like shitty LED transparent $10 fans dude....
maybe your fan curve is too steep near the place where your temps fluctuate while gaming?
try ramping up the fans in an exponential curve like so
13161557_1208260209192345_1692649165_o.p
and not a steep curve like so
13170756_1208260342525665_1542938948_o.p
See if you can control fan profiles in the BIOS.  Should work much better.
PC Build
Desk Build
they are 3 pin fans
did you set the fan header that the fans are connected to to DC control in the bios instead of pwm control?
I will check that
CPU-Intel I7 6700k
You could also look at getting in line resistors for your fans.  Noctua calls them "low noise adapters" but I think other companies make them as well.  The idea is it restricts your fan's maximum speed.
PC Build
Desk Build
i was under the impression that the whole point of ai suite was to do that for you?
CPU-Intel I7 6700k
Well sure, but if software isn't working sometimes you need a hardware solution.  Should be cheaper than an external fan controller anyway.
PC Build
Desk Build
