This is my first post in this forums. I'm making a gaming PC. Here is the list:
http://pcpartpicker.com/p/LNb2Q7
How is it? What do you think about it? How much FPS should I expect from 1080p?
I came here because I'm a big fan of Linus and I thought that, since Linus is the best tech guy in the world, his forums must be great !!!!
Any comments appreciated.
Thanks.
https://linustechtips.com/topic/593459-my-first-gaming-build/
That is one of the most perfect builds I've seen from a new person ever. Should expect 50-60 across the board (380X is quite powerful) and welcome to the forums :D Also, consider waiting on the new graphics cards from AMD and Nvidia, releasing 'soon' (1 to 2 months).
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/593459-my-first-gaming-build/#findComment-7717755
1 minute ago, AdikRahman said:
GTA V, Watch Dogs, Mafia III (When it releases), Rise of Tomb raider
depends on your settings but you should be able to reach 60 fps no problem :)
https://linustechtips.com/topic/593459-my-first-gaming-build/#findComment-7717761
14 minutes ago, AdikRahman said:
looks good. i would go with the fractal design core 2500 (you dont need extra fans then), without an optical drive and with an ssd though.
also the monitor isnt good value you can pick up a freesync monitor for that price.
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
https://linustechtips.com/topic/593459-my-first-gaming-build/#findComment-7717776
16 minutes ago, AdikRahman said:
@TheRandomness
Thanks so much. But I can't wait. I've already waited 1.5 months for all the parts that I selected to arrive at my local store :D
Why no SSD?
https://linustechtips.com/topic/593459-my-first-gaming-build/#findComment-7717789
I would have bought Fractal Design or NZXT if it was available here. But unfortunately my only options are Thermaltake Versa N21 or H25.
And the optical drive is for OS install and for using some old disks that I have in my home.
I don't care about monitors but, I'm not buying from online. I'm buying from a local shop and it's quite cheap here :D
https://linustechtips.com/topic/593459-my-first-gaming-build/#findComment-7717790
you can install the os from a usb stick (its faster that way). cant your local shop order parts for?
i would highly recommend am ssd. it makes everything faster. as said i would try to put it in somehow.
https://linustechtips.com/topic/593459-my-first-gaming-build/#findComment-7717820
18 minutes ago, AdikRahman said:
SSD will exceed my budget :(
if you can't get an ssd now, you can always add it in later. make a 100-200gb boot partition, than once you get your ssd, clone everything from that partition to the ssd.
https://linustechtips.com/topic/593459-my-first-gaming-build/#findComment-7717826
The motherboard (while it looks good) is a tad on the pricey side though. You can find some decent H170 boards at this price, but if you like its looks and don't need things like RAID then just get it.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/593459-my-first-gaming-build/#findComment-7717914
EXACTLY!!!!
DON'T need RAID, LOVE the LOOKS
https://linustechtips.com/topic/593459-my-first-gaming-build/#findComment-7717923
Can you guys tell me something?
The RAM I selected is fine I guess. But I'm not sure if it's in there stock. And they don't have any other kit RAMs so, Should I buy 2 single 4GB RAM and hook them up or is that a bad idea? Or, Should I buy 1 single 8GB RAM?
https://linustechtips.com/topic/593459-my-first-gaming-build/#findComment-7717931
I doubt you will ever need more than 16GB ram in total, so 2 single 4GB sticks should be fine.
https://linustechtips.com/topic/593459-my-first-gaming-build/#findComment-7717969
7 minutes ago, AdikRahman said:
Sorry but I think you misunderstood.
I'm talking about kits. Which should I buy?
(1X8GB) or
(1X4GB) 2 of them
buy the 1x8gb stick of ram so that you can leave more room for future expansion.
https://linustechtips.com/topic/593459-my-first-gaming-build/#findComment-7718016
So if I buy a 8GB then buy another 8GB of the same model in the future, will it work?
it should work.
https://linustechtips.com/topic/593459-my-first-gaming-build/#findComment-7718044
Yes, it would mean you will get less effective bandwidth if you have one since you can't have them in dual channel.
https://linustechtips.com/topic/593459-my-first-gaming-build/#findComment-7718276
Thanks guys. I have to admit, you guys are awesome!!! Really, LinusTechTips Forums are amazing. I'll try to spread the word to everyone I know :D
All of you have been VERY VERY helpful.
I bought this PC and gaming on it is phenomenal. Thank you all for helping me out :D
https://linustechtips.com/topic/593459-my-first-gaming-build/#findComment-7738163
