I recently watched @Slicks video on the LTT YouTube channel about building your own test bench and I had an old case I don't need so I decided to strip the case down and build my own test bench! It's not the prettiest and yes I used hot glue to attach the legs, but it does what I need and I'm excited to start using it :D
If anyone else has built their own test bench/ anything else PC related, I would also love to see what you have built (post in the comments) :)
My Main PC:
CPUi5 3570k CPU Cooler: Cooler Master Hyper T4 Motherboard: Asus p8z77-v pro  RAM: Crucial Balistic 2x4gb  GPU: Two PNY GTX 680's in SLI Case: Some rando Antec one  PSU: Thermaltake 1000w  Display: HP Elite Display 321i 23''  Storage: Samsung 840 Evo 128gb, Seagate Barracuda 1tb
https://linustechtips.com/topic/593327-home-made-test-bench/
The first pic makes it look lop sided but it isn't that lop sided irl :P
My Main PC:
https://linustechtips.com/topic/593327-home-made-test-bench/#findComment-7716520
2 minutes ago, wcreek said:
I wonder if the PSU would sag/droop since it doesn't appear to be supported by anything.
i plan on putting the psu just on the bottom
My Main PC:
https://linustechtips.com/topic/593327-home-made-test-bench/#findComment-7716539
Oh okay, I wasn't sure if you were planning on putting the PSU where the original PSU slot was.
Also I noticed that HP logo on the side panel. Would the case that you salvaged possibly had been an HP case in its former life?
a Moo Floof connoisseur and curator.
:x@handymanshandle x @pinksnowbirdie || Jake x Brendan :x
Youtube Audio Normalization
https://linustechtips.com/topic/593327-home-made-test-bench/#findComment-7716552
The HP side panel and the the other sheets of metal came from the same case
My Main PC:
https://linustechtips.com/topic/593327-home-made-test-bench/#findComment-7716724
So basically, yes. The case you salvaged was from an HP case.
https://linustechtips.com/topic/593327-home-made-test-bench/#findComment-7716754
yes it was xD
My Main PC:
https://linustechtips.com/topic/593327-home-made-test-bench/#findComment-7716760
1 hour ago, thekeemo said:
i added some cardboard to the bottom to put on a hdd cage xD
My Main PC:
https://linustechtips.com/topic/593327-home-made-test-bench/#findComment-7716796
