So I am planning to build a new pc, I already have the following components:
Case - Fractal Design Core 500 mATX
Fans - Thermaltake Riing 140mm red led
PSU - Corsair CX450M 2015 edition ( New parts don't need that much power, right?)
But I don't know what to buy next, what do you think would be the best pc I could get for 1200$ while using the components I already have, can you please post pcpartpicker lists?
My main game is CS:GO, but I would like to play GTA V and a very cpu-based game: Microsoft FSX.
https://linustechtips.com/topic/593052-best-pc-for-1200/
Is that the grey CX?
https://linustechtips.com/topic/593052-best-pc-for-1200/#findComment-7713715
Ge a new PSU if you want to game with that rig. the corsair CX series is firehazard in a 1200$ mid-/high-end rig.
I would advise you to get an i7 for that purpose but wait for the new GPUs to come out.
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/593052-best-pc-for-1200/#findComment-7713717
Actually, the new grey units are okay.
https://linustechtips.com/topic/593052-best-pc-for-1200/#findComment-7713721
but still?I mean come on, if you are willing to spend 1,2 grande ...
3.Use
https://linustechtips.com/topic/593052-best-pc-for-1200/#findComment-7713728
15 minutes ago, Lum1nou5 said:
I mean if there's need to, but probably no.
That cx450m should be fine if you don't oc, but you may have less gpu choices if pascal/polaris proves to be too power-consuming.
https://linustechtips.com/topic/593052-best-pc-for-1200/#findComment-7713785
Bam:
PCPartPicker part list: http://pcpartpicker.com/p/XzpHf7
Price breakdown by merchant: http://pcpartpicker.com/p/XzpHf7/by_merchant/
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  ($299.99 @ SuperBiiz)
CPU Cooler: Corsair H55 57.0 CFM Liquid CPU Cooler  ($59.86 @ Amazon)
Motherboard: ASRock B150M-ITX Mini ITX LGA1151 Motherboard  ($75.98 @ Newegg)
Memory: G.Skill Aegis 32GB (2 x 16GB) DDR4-2133 Memory  ($99.99 @ Newegg)
Storage: PNY CS1211 240GB 2.5" Solid State Drive  ($59.00 @ Newegg)
Storage: Toshiba Product Series:DT01ACA 1TB 3.5" 7200RPM Internal Hard Drive  ($42.99 @ NCIX US)
Video Card: XFX Radeon R9 Nano 4GB Video Card  ($489.99 @ Amazon)
Case: Fractal Design Core 500 Mini ITX Desktop Case  ($59.99 @ Amazon)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($0.00)
Total: $1187.79
Generated by PCPartPicker 2016-05-08 10:44 EDT-0400
Get some extra fans I would recommend.
https://linustechtips.com/topic/593052-best-pc-for-1200/#findComment-7713798
1 minute ago, lee32uk said:
Yeah you don't need that much. Ram is pretty cheap at the moment, but 32GB is overkill for a gaming pc.
You can get a cheaper cooler as well such as the CM 212 Evo. The Fractal Core 500 takes up to 170mm.
Eh, I was just throwing stuff in at that point.
https://linustechtips.com/topic/593052-best-pc-for-1200/#findComment-7713885
25 minutes ago, Starelementpoke said:
Bam:
Total: $1187.79
what about a dual rad? not possible?
3.Use
https://linustechtips.com/topic/593052-best-pc-for-1200/#findComment-7713905
9 minutes ago, Starelementpoke said:
Not sure why he needs a liquid cooler or 32gb of ram. Maybe a larger ssd instead?
https://linustechtips.com/topic/593052-best-pc-for-1200/#findComment-7713925
8 minutes ago, Starelementpoke said:
Sorry, can you explain? I'm doing a shit load of multitasking right now.
3 minutes ago, Starelementpoke said:
Magh, small case, thought water cooling would be a good idea okay? I'm multitasking right now.
A 240 rad that fits in the top like the artic liquid something 240
3.Use
https://linustechtips.com/topic/593052-best-pc-for-1200/#findComment-7713962
4 minutes ago, Starelementpoke said:
Oh, I get it. I didn't think it'd be really needed since it's locked.
Damn, well you got me there :P would still be quieter though ...
3.Use
https://linustechtips.com/topic/593052-best-pc-for-1200/#findComment-7713996
