Recommend a NAS chassis?
Go to solution Solved by Jarsky,
$340 for a Norco RPC-3116 http://www.amazon.com/NORCO-Mount-Hot-Swappable-Chassis-RPC-3116/dp/B00BQY37HC
Supports up to 16 drives, and has standard mount for ATX PSU & Motherboard layout.
It also has 80mm fan mounts so not too loud.
Just keep in mind that these type of chassis have a SAS backplane so you'd need HBA cards at the very least.
Newegg has some SuperMicro 1RU server chassis with 4 drive bays for around $230 but the price goes up to around $450 when you jump to 8 drive bays. For better cooling and noise reduction I might suggest going with a 2RU chassis which should bring the price down or maybe looking at something like a Dell R610 which is 1 RU, supports 6 2.5" drives, and is very quiet.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/592609-recommend-a-nas-chassis/#findComment-7709814
Rack mounted would be nicer, but if needed i could always swap to a traditional case, my original idea was to buy a wall mounted rack and have a 2u server and a 1u nas, I was able to find a good deal on monoprice, but unfortunately the 1u chassis only supported I believe one drive. The idea is to keep it all in a closet for noise supression. The setup would have a tiny desk to the side with a monitor and keyboard and mouse, while the server and nas are simply mounted to the wall.
https://linustechtips.com/topic/592609-recommend-a-nas-chassis/#findComment-7710820
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/592609-recommend-a-nas-chassis/#findComment-7715547
Have you taken into account the depth for a rack chassis? Most 1 and 2U chasis are 600mm+. There are a few small form factor 1U designed more for a service to run in them rather than a NAS.
https://linustechtips.com/topic/592609-recommend-a-nas-chassis/#findComment-7717367
http://www.amazon.com/dp/B002AU3NVQ?psc=1
I finally decided on this chassis, It comes with 4 hotswappable drivebays for a raid 10, and room (according to the product page) a atx board, but I think i'm just going to stick with a mini itx board, namely this one: http://www.amazon.com/ASRock-Rack-Mini-Motherboards-C2550D4I/dp/B00GG94YDS/ref=pd_bxgy_147_img_2?ie=UTF8&refRID=19XFQXY57F1JAXQKF5JD
https://linustechtips.com/topic/592609-recommend-a-nas-chassis/#findComment-7721380
You are aware how loud that will be?
https://linustechtips.com/topic/592609-recommend-a-nas-chassis/#findComment-7721398
25 minutes ago, RangerLunis said:
Theres ways to get around it, I'm not totally sure if I can replace the fans but it will be in a closet and i'll find other methods to cool it.
Issue with 1U that you'll run into is that all of the quiet fans won't be able to move enough air to keep things cool though you might be able to get away with it because of the board you're using. The power supply though will still be really loud.
https://linustechtips.com/topic/592609-recommend-a-nas-chassis/#findComment-7721486
So I did some research this morning and found some 40 mm fans compatible from noctua https://pcpartpicker.com/part/noctua-case-fan-nfa4x10
They go up to about 4500 rpm which I'm not totally sure is as strong as some other fans, but they stay pretty silent i'm sure and even come with rubber grommets.
https://linustechtips.com/topic/592609-recommend-a-nas-chassis/#findComment-7724104
