Is there something better than Be Quiet! Dark Rock Pro 3?
Solved by Oshino Shinobu,
The NH-D15 performs a bit better and is a little quieter. The DRP3 actually uses one 140mm fan and one 120mm. Between them, there's no significant difference, so if you care about looks and want the stealthy look, go for the DRP3. Both are very good, can't really go wrong.
EDIT: There's also the Phanteks PH-TC14PE which isn't quite as good as the DRP3 or NH-D15, but looks nice (comes in a variety of colours) and can often be found cheaper than the other two.
Quite a good comparison of them over here. DRP3 seems to be quietest at low fan speeds (not by much).
