CPU fan twitching? Cpu fan smoking? help!!
logan
So a friend of mine gave me a computer to fix, he said it needed a new cpu fan
SOOOO
i did some test: :ph34r::ph34r:
1. booted pc couple times, the fan twitches like it wants to go, but doesn't do anything, says "511-CPU fan not detected"
2. plugged in a different 4-pin cpu fan to see if it would move.....it started smoking
3. plugged in a 3-pin fan and held it in front of the still placed cpu fan, the 3 pin made the 4 pin move, and it booted fine and dandy
He said i could buy him a new cpu cooler (well..purchase it for him, but it would take me while to see what cooler to use with his case and such)
Picture 1 = what comes up when turning on pc (except for when i did test 3)
Picture 2 = the 4-pin connector of the fan that "twitches"
Picture 3 = the 4-pin connector of the fan that smoked
Picture 4 = not clear picture of where 4-pin/3-pin were plugged in
Picture 5 = pic of motherboard
THAT MOMENT YOU DISASSEMBLE YOUR COMPUTER....AND REASSEMBLE IT ....JUST SO SENPAI WILL NOTICE YOU
Can you provide pictures of the board and the slots that the 3 and 4 pins were plugged into?
Current Build: Core i7 4790k @ 4.6, Asus Maximus VII Hero, Corsair Vengeance Pro 2400mhz 8gb (2x4gb), GTX 980ti, NZXT Kraken X61, Fractal Define R5  EVGA Supernova B2 850w, Some 300gb hard drive.
http://pcpartpicker.com/p/W7CNrH
i just updated it with new pics, even though pic 4 i couldnt get clear...sorry
As far as i see, I really cant tell that anything is really wrong on the board.
so would i just purchase a new cpu fan? orrr?
Erm, yea i would give that a shot. If that doesn't work then return it and after that point i really don't know.
