Electrical interferance Studio Monitors help???
Solved by NoobCase,
A theory of my own. Could it be that wireless inteference is transfered by the powercord/ac lines? Did you also change the power cards for the monitors or is the one on the left using the same? If that makes any sense
l3eyond ·
1
Serendipity1344 ·
Posted in Graphics Cards4 -
1
1
5
1
toxic_worper ·
16
1
