THe 598's have a larger sound stage and  kinda better sound quality but m50 has lots of bass,
in my opinion i would go for 598's its more bang for your buck
2 minutes ago, Tedster said:
no one replied, people get desperate
Also
Quote
Unless you NEED the bass, Sennheiser 598. Even if you "NEED" the bass, you might still go with the 598. The open design will give you a better sound stage, and will generally be better across the board.
As another note, I often see Head-Fi-ers talk people down from the 598's to the 558's because the SQ delta is apparently small. I will let those people speak for themselves, but it is something to keep in mind.
And by the way, the M50's are great, and I would totally recommend them if you need isolation. The X version is supposed to sound a little better, but more importantly, it comes with three interchangable cables, offering more versatility than its older brother.
https://linustechtips.com/topic/587927-help-headsets/#findComment-7657413
1 minute ago, Tedster said:
What was wrong with this?
Not fast enough response, need speed and excitement.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
https://linustechtips.com/topic/587927-help-headsets/#findComment-7657416
