5820K and 980, or 4790K and 980Ti?
9 minutes ago, TheNerdyCanadian said:I've used the original H100i before, never noticed any sound when it was in an R4
Couldn't find any GQ, only G2 if that's what you meant
I've used Samsung before, but it's a $50 price difference for 20GB~
I'm going for the R5 because i really like silence
Well on paper x61 is the worlds silence cooler in that class atm, but if you dont notice difference then its fine. X61 should cool better but if you dont want to pay extra cash, just dont.
At first i was going for P2 aswell, but in Germany there is 40Euro difference between P2 and GQ. Look at G2 if there is no GQ it should be cheaper and if its something like 20/30$ then buy G2, there isn't really a lot difference beetween P2 and G2.
Well 50$ is alot, stick to your one you pick then.
H440 is silent too lol, but its really up to you. I personally got H440 red and i am really happy with it. I guess it has better airflow at all over the R5, but again if there is a lot price difference simply stick to R5.
There is 177$ price difference beetween 980 and 980TI and you can find even cheaper 980Ti, i would personally save up for 980Ti for long run. If time not issue as i said up wait for GTX1070/80 and 980/980ti price suppose to drop.
Best of luck and happy building.
