I am looking for a case that is made to be able to watercool like crazy. Well not crazy just some mild watercooling. I currently have a corsair 760t and I love the case but I feel like it just doesn't have enough room for good watercooling. I want to do a 360mm and a 280mm rad system but I can't seem to find a badass case without any compromises. Any suggestions?
https://linustechtips.com/topic/586410-case-made-for-water-cooling/
caselabs
As enderman said caselabs is good if you want to get something that does not cost that much the Fractal Design Define S is made for water cooling and is a great case. In fact it is the case I have right now. It can easy fit a 360mm and a 280mm rad.
Edit: It also has a mount for the reservoir.
My Work in Progress PC http://linustechtips.com/main/topic/522048-xeon-build/ <-- That PC was built but never booted:(
My Work in Progress PC 2.0 https://linustechtips.com/main/topic/540583-xeon-build-20-code-name-xenox (Hopefully this one boots.)
