2 Pin fan connectors
Afranqui
Hey all. I recently bought a GTX 970 hybrid and was looking to replace the stock fan that comes with the external aio liquid cooler. Upon looking at the fan i noticed that it was a 2 pin connector. I modified the connector to accept a 4 pin but that fan would not turn on. Could a non PWM fan (a 3 pin) work with a two pin adapter? Also what is a two pin fan? I tried looking on other sites but I didn't find a website that explained it well to me. Thanks
27304D49558C02200B5F64
2 pin doesnt have that yellow
just gnd and vdc
move the fan over one and it should work
why not just use a header on your motherboard to control it?
-sigh- feeling like I'm being too negative lately
It will be controlled by CPU temps not GPU temps then
pretty sure there are softwares to change fan speed according to gpu temp
correct me if im wrong
There is speed fan but not all boards support it
I have an extra noctua fan that i was planning on sticking at 75% to see if that would be enough to keep it cool under load. The stock fan is just really loud.
Doesn't work, since there's no feedback of the fan rpm. My Asus board doesn't even detect it and it ran at full speed all the time.
you can change the header to dc control instead of pwm in the bios
Could do, if only the fan would've gotten detected. Which it didn't in my case.
well i plugged a 3pin fan into my header and it didnt get detected by fan xpert, changed to dc control and its working flawlessly now
go try it if you didnt
Can't, I'm abroad. But I think I tried and it didn't work like that with the 2 pin.
That's what I did in the end, with EK Vardars.
2 pin of course not... but the OP is trying to use a 3 pin fan
Too tired to read properly, you're right.
u meant two tired? as in 2 pin fans? ill excuse myself now
