I am putting together a budget PC, and I already have 8GB DDR3 of Ram and 1 TB, I am thinking of adding to my build;
Processor - AMD Athlon X4 860K Black Edition
Mobo- http://www.newegg.com/Product/Product.aspx?Item=N82E16813128763
Video Card- Evga GTX 950 2GB SC
Power Supply- Evga 500W
Would this in your opinion make a decent gaming PC for working within a budget?
https://linustechtips.com/topic/583000-building-a-budget-pc-need-help/
4 minutes ago, canadamade said:
I am hoping to go no more than $400.
As a reminder, I do have the 1TB and 8GB of RAM, and a Micro ATX tower
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  ($111.99 @ SuperBiiz)
Motherboard: ASRock H110M-DVS/D3 Micro ATX LGA1151 Motherboard  ($49.98 @ Newegg)
Video Card: XFX Radeon R9 380 4GB Double Dissipation Video Card  ($169.99 @ Newegg)
Power Supply: XFX XT 600W 80+ Bronze Certified ATX Power Supply  ($51.98 @ Newegg)
Total: $383.94
Generated by PCPartPicker 2016-04-16 23:57 EDT-0400
With this you should be able to play all games at low-high (dependent on game) settings 60 fps
So it's $400 minus the hard drive, DDR3 memory, and case?
If so here, 880K with a beastly FM2+ board, and a 4GB 380
just save up a bit more for the taxes/shipping
PCPartPicker part list: http://pcpartpicker.com/p/Q9r9xr
Price breakdown by merchant: http://pcpartpicker.com/p/Q9r9xr/by_merchant/
CPU: AMD Athlon X4 880K 4.0GHz Quad-Core Processor  ($90.27 @ NCIX US)
Motherboard: ASRock A88M-G/3.1 Micro ATX FM2+ Motherboard  ($62.98 @ Newegg)
Video Card: XFX Radeon R9 380 4GB Double Dissipation Video Card  ($189.99 @ Newegg)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($55.99 @ SuperBiiz)
Total: $399.23
Generated by PCPartPicker 2016-04-17 00:30 EDT-0400
