Audio Interpolation
Go to solution Solved by Volbet,
You can, but the audio quality will at best remain the same and the file size will increase.
I don't really see a reason to do it, but you can.
You could load all your 128kbps files into Audacity and then export them as 256kbps files.
I've been cleaning up my music library during the past few days, tagging songs, putting everything into a single (mp3) format, and that brought to me a though: is it possible to interpolate music in much the same way you can video?
Like can software "average" between samples, to, for example, convert a 128kbps to a 256kbps song?
RuneScape is still the best MMO ever made.
Program on Mac | Game on PlayStation | Homelab on Ubuntu
https://linustechtips.com/topic/582727-audio-interpolation/
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/582727-audio-interpolation/#findComment-7605826
Sure, if you've a touch of the OCD and want every song to have an identical bitrate, you probably can. However, you won't see any improvement in audio quality.
You can export something as a higher bitrate file using conversion software like Switch or Audacity, but you'll only be increasing file size.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/582727-audio-interpolation/#findComment-7605827
