I am interested in 3D printing. I don't really want to spend a lot of money though. I found this kick starter, https://www.kickstarter.com/projects/1403065126/trinus-the-affordable-all-metal-3d-printer/community
Now everything about it looks good, except it uses Pango as a printing software. So is pango user friendly? Is it easy to work with? It can't be that bad if all I am doing in Pango is putting my STL file in and making sure it will properly print right?
EDIT:
I took a maker camp for 3D printing so I have basic knowladge of CAD software like Sketchup.
Edited by TheSlicingEdge
https://linustechtips.com/topic/582722-need-help-with-buying-a-3d-printer/
It says you can use other software in the video.
Ive never personally used/owned a 3D printer. So I cant really comment.
If it was me however, I would not worry too much about the software as long as it has positive reviews. I can learn how to use it.
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
Mkay...
Alright, prepare yourself for some knowledge. You want to stay away from 3D printers that are on kick starter. If you hear about them from kickstarter and not a professional ad, that means they don't have enough money to build their product, let along advertise properly. Next, I have learned the hard way that when it comes to 3D printers, less is less. You do get what you pay for in the quality of the parts, how sketchy the electronics are, and how well the damn thing works when you pull it out of the box/finish putting it together. There is quite a juxtaposition between spending $1000+ on a printer, or $500>.
Word on the street is that the Printrbots are some of the best damn printers you can get for less than a thousand, but they're still not as good as a more refined machine such as the Ultimaker. They have limitations, build volume, speed, lack of proper heating and cooling of the print. But I can guarantee you that a Printrbot will perform a lot better and cause much fewer headaches than an unfinished product from kickstarter.
See my signature for suggestions.
ASU
Just now, TheSlicingEdge said:
Thanks alot this was helpful I will not be buying the Trinus. What printer do you have? I checked out your sig some of them look good for my budget.
I have an Ultimaker Original that now has a heated bed upgrade kit on it. Prints like a dream.
ASU
17 hours ago, TheSlicingEdge said:
no it dosnt print metal.
It does Alluminium though
ummm, no. Printers that can print in metal use a laser to melt metal power (such as aluminum) layer by layer into the figure. They also cost more than your house. This little $300 probable piece of garbage will only do PLA out of the box, and ABS with the addition of a heated bed.
ASU
On the Kickstarter video, he said it prints aluminum?!!!! I know it is probably not full aluminum and some crappy compound, but it still is aluminum.
Usually metallic filaments are just PLA with metal powder mixed in. Check out Colorfabb copperfil.
ASU
I would be wary of that 3d printer. I have yet to see a 3d printer kick starter that aims for a price and quality like that succeed. I can tell you right now there is no way in hell they will be able to sell a 3d printer with a linear rail system like that at $299 and still have enough money left to pay their employees. Far too small of a margin.
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
Even if they do pull it off for that price, there will be a compromise somewhere. More than likely, the electronics. I know from unfortunate first hand experience that bad electronics are more of a pain than the hit a more expensive printer would have on your wallet. Everyone likes the idea of cheap, but with 3D printers, you really do get what you pay for.
ASU
