Does USB 3.0 hub slow down data transfer?
2 minutes ago, dachanmin said:Not sure what you mean... sorry I'm a tech noob lol
So if I have a 4 port USB hub,
if I just plug in the SD card reader without anything else, I'll have the full speed
But if I have 3 other things plugged into the hub, it'll spread the power and thus decreasing speed of my SD card reader??
the theoretical speed of USB 3.0 is 480Mbps
you connect an SD card, which typically uses about 40Mbps,
so you have 440Mbps left for those 3 ports to share
in another situation,
lets say you connect 4 external storage, one is an SSD with 300Mbps, hard disk have 100Mbps
means the speed your things need is 600Mbps, but USB 3.0 can only handle 480Mbps, so some of the things will run slower, if not all together run slower
