Replace stock CPU cooling fans
Solved by 19_blackie_73,
19 minutes ago, AlreadyExist said:HI,
I'm using i5-4590 with Cooler Master Hyper T4 air cooler with fan speed is 600~1800 RPM.
Can I replace this fan with some more powerful, for example Noctua 3000 RWM?
do you like to have a jet engine?
TBH I don't think you get much better temps with some high rpm fans. But i guess you can replace them (as far as i can tell from pictures)
YOu'd be better of with a larger heatsink
