GPU does not downclock at idle
Go to solution Solved by Moonzy,
Just now, 19_blackie_73 said:
shure for the mobo, but also the GPU Bios?
BTW you were right, it is ShadowPlay causing this on a specific DP of the GPU.
download gpu-z, it should show you the bios version (i think)
disable desktop shadowplay
i just remembered about shadowplay because i had to turn on desktop capture just because it wont turn on automatically in games lol
and its causing my gpu to run at 1k-ish core clock full time
Hey guys,
earlier that day I started this thread here:
I installed the latest nvidia driver, which solved the issue that the gpu is running at 1177MHz at idle instead of the 135MHz which it is supposed to and what it did the last couple of months since I built the PC back in May 2015 (rig is in my sig).
Well it solved it sort of as you can guess: it solved it for exactly 5 hours. After watching a few videos on youtube via edge and then shutting it down for the last 4 hours, starting it again few minutes back and controlling whether it is now solved, the problem is back. I'm running on Win 10 64bit, latest updates, nVidia driver 364.72. Does anybody now how to fix this? I don't like to run it at this speed all the time if there's no use for if you understand.
Thanks in advance again!
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/578692-gpu-does-not-downclock-at-idle/
If you have a 120+Hz monitor you are bound to have this issue. It's a driver issue that has been around for several months
Driver 364.72 has a bad reputation.
You might want to go back 1 version (364.51) and check if that helps.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
2 minutes ago, SPAS-ID said:
how do you check it ?, try to use Afterburner
I use afterburner
I'm using a standard 60Hz Panel via displayport (Dell P2314H)
- Ryzen Build -
2x Dell UP2516D
I use afterburner
Hmmm. Odd. Does the higher idle clockspeed affect anything? If it's just that I'd say it's nothing to worry about - you will simply have increased power draw at idle
idle temps are 5-10°C higher... so a thing I really don't like to have.
Just tried it with a vga cable I had laying around... and now it automatically downclocks.
- Ryzen Build -
2x Dell UP2516D
It's fine - due my 2 screens my card idles at 42*C since clocks are maxed when you have more than 1 screen - it won't affect anything.
lol it really doesnt matter unless it affects your performance
if you're really concerned about power draw, dont leave your computer turned on and unattended :P
(just remembered something)
is your shadowplay turned on? `-`
-sigh- feeling like I'm being too negative lately
10 minutes ago, 19_blackie_73 said:
I use afterburner
Make sure in afterburner settings Force Constant Voltage is NOT checked:
And in the nvidia control panel, this (sorry for french...make sure it's not set to ''max performance'':
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
its just you, iam using latest driver and latest afterburner, result showed that my GPU running at 135MHz135f4729d8.png
Key Switches Guide | LLT Beginner Guide | GPU TDP & Power Consumption Explained | PSU Tier
s a d b o y s 2 0 0 1
@i_build_nanosuits: Yes both were exact like you said, no forced voltage nor max performance.
@Moonzy: ShadowPlay is turned on, I try this if the error occurs again. I tried another DP and now it seems to work.
Thank you all for your quick help!
BTW: how do I see which GIGABYTE Bios I have? http://www.gigabyte.de/products/product-page.aspx?pid=5209#bios there are various Fxx Versions, but I didn't find a way to see which one I have.
- Ryzen Build -
2x Dell UP2516D
same here:
3 minutes ago, Moonzy said:
it should be written in a corner when you enter the bios screen lol
- Ryzen Build -
2x Dell UP2516D
tech powerup GPU-Z will tell you a lot of good stuff...get it:
