Hi,
I currently have a R9 390, and I'm thinking of selling it to my brother when he builds his PC so he can get a better card than he otherwise would have, and I can get an upgrade. The problem is, I don't know what to go for. I have a 4690k which I could easily overclock, so I was thinking of a 980 as that's the maximum I can pay. Any ideas?
Thanks,
Ron.
https://linustechtips.com/topic/578246-best-upgrade-for-me/
4 minutes ago, ronstig said:
Hi,
Thanks,
Ron.
save money and get pascal when it comes out then sell your 390 to your brother.
done.
/thread
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/578246-best-upgrade-for-me/#findComment-7561230
done.
/thread
I thought that pascal was going to mostly be high-end GPUs? Do you think some will be released at the same price as the 980?
https://linustechtips.com/topic/578246-best-upgrade-for-me/#findComment-7561245
Pascal is an architecture, so it'll have the same iterations and price scheme as maxwell. There will be the high-end, mid and low.
https://linustechtips.com/topic/578246-best-upgrade-for-me/#findComment-7561258
well if nvidia follow what they've been doing
you'll see the x70 and x80 cards first, which should be within your budget lol
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/578246-best-upgrade-for-me/#findComment-7561331
nope, there will be different tiers. high, mid, low. same as every time they release a new card. the first ones will be the equivalent of a 970 and 980. probably called the x70 and x80.
Old Rig
https://linustechtips.com/topic/578246-best-upgrade-for-me/#findComment-7561394
