So after succesfully reviving my internet connection after it stopped working by resetting my modem and screwing in my coaxial cables harder i get a LOT of packet loss and jitter, these are my results after only a few ping requests to google
Reply from 216.58.209.99: bytes=32 time=16ms TTL=56
Reply from 216.58.209.99: bytes=32 time=9ms TTL=56
Reply from 216.58.209.99: bytes=32 time=10ms TTL=56
Reply from 216.58.209.99: bytes=32 time=8ms TTL=56
Reply from 216.58.209.99: bytes=32 time=11ms TTL=56
Reply from 216.58.209.99: bytes=32 time=4ms TTL=56
Reply from 216.58.209.99: bytes=32 time=1189ms TTL=56
Reply from 216.58.209.99: bytes=32 time=128ms TTL=56
Reply from 216.58.209.99: bytes=32 time=12ms TTL=56
as you can see it jumps up to 1189 ms randomly which didnt happen before
I also recieved these results after a few minutes of running pingplotter towards various websites
Hop Sent Err PL% Min Max Avg  Host Name / [IP]
 1    25   0 0.0   0   1   0  [192.168.0.1]
 2    25   0 0.0   6  11   8  c213-200-142-141.bredband.comhem.se [213.200.142.141]
 3    25   0 0.0   7  57  11  [213.200.164.217]
 4    25   0 0.0   8  12   9  [213.200.163.237]
 5    25   0 0.0   7  12   9  as15169-te-tc1.sthix.net [192.121.80.47]
 6    25   0 0.0   7  50  13  [209.85.250.192]
 7    25   0 0.0   9  13  10  [209.85.253.151]
As you can see the packet loss is pretty high at 8% for google, and the jitter is pretty extreme at times, and sometimes even not responding at all
Does anyone know how to fix this, since fiddeling with the coaxial cable more doesnt seem to help that much
Long live Stalin, he loves you; sing these words, or you know what he’ll do!
https://linustechtips.com/topic/578196-extreme-coaxial-cable-jitter-and-packet-loss/
27 minutes ago, Arc_Jester said:
First you should check your wiring and if everything is fine on that end then contact your ISP and get them to run a line test to check their lines.
So i fiddled around a little with my cables and re-run the test, now i get much better results
Target Name: www.google.com
         IP: 83.255.235.109
  Date/Time: 07-Apr-16 20:08:09 to 07-Apr-16 20:26:15
 1  1087   0 0.0   0  18   0  [192.168.0.1]
 2  1087   0 0.0   2  42   7  c213-200-142-141.bredband.comhem.se [213.200.142.141]
 3  1087   0 0.0   3  65   8  [213.200.164.215]
 4  1087   0 0.0   3  59   8  [213.200.163.235]
 5  1086   0 0.0   4 120  20  [213.200.162.34]
 6  1087   0 0.0   3  68   8  www.google.com [83.255.235.109]
BUT the problem is that my jitter has increased a ton since last, it has gone from 1 to 2.5, although the jitter graph is much better this time
Is this result normal, or should i call my ISP now that ive improved it this much?
