100mbps when Ethernet but 40 when wireless?
Go to solution Solved by Iankiller99,
Well I found a reddit post that may help you, one person said that the tz series of routers are their budget models, and the advertised speeds are often higher than the actual speeds. Effectively your router most likely bottlenecking your speed. Also your router is pretty old, I could hardly find any hardware specifications. The manufacturer deleted the product pages so that didn't help. Either way i'm still an advocate of if you can connect via Ethernet than do.
https://www.reddit.com/r/sysadmin/comments/20wkw1/how_fast_is_the_sonicwall_tz_potential_bottleneck/
Thank you so much for taking the time to research this!
Current Build: Core i7 4790k @ 4.6, Asus Maximus VII Hero, Corsair Vengeance Pro 2400mhz 8gb (2x4gb), GTX 980ti, NZXT Kraken X61, Fractal Define R5  EVGA Supernova B2 850w, Some 300gb hard drive.
http://pcpartpicker.com/p/W7CNrH
No problem.
Case: NZXT H440 Blue/Black Special Edition   CPU: i5-4690k @ 4.3GHz    Cpu Cooler: Cryorig H5
Graphics Card:  Gigabyte Windforce GTX 780ti OC 3GB Stock Clock 1020MHz Boost Clock 1085MHz   Motherboard:  Asus Z97-A ATX Motherboard
RAM: 2x8 Crucial Ballistix Sport @ 1600MHz   Storage: 2TB Seagate Barracuda @ 7200rpm, 128GB SanDisk Ultra Plus SSD Audio: Logitech G933 Artemis Spectrum Wireless Gaming Headset  Keyboard: Logitech G910 Orion Spark Mouse: Logitech G502 Proteus Core
