I just upgraded my set up from 4x2gb 1333 sticks to 2x4gb Kingston HyperX Fury 1600.
Something very odd is happening though. Either stick will work on it's own in the A1 slot. They will work in A1 and A2 in single channel as well. In A1 and B1 (dual channel) they will not work. My computer gives an error code of 33 and then turns off, restarts, turns off, restarts, forever unless I turn it off myself. I've tried hitting my clear Cmos button as well but that does not work.
Any suggestions?
Computer
Case - NZXT Phantom Full Size
Motherboard - Asrock Z77 Extreme 4
CPU - i5-3570k OC'd to 4.4 GHz
CPU Cooler - Hyper 212 Evo
RAM - (2) 2gb G.Skill Ripjaws 1333 and (2) 2gb Patriot 1333   Trying to install 2x4gb Kingston HyperX Fury 1600
GPU - (2) 2gb EVGA 770 Superclocked SLI
HDD - WD 2tb Green and WD 500gb Blue
SSD - (2) 120gb Sandisk
Monitors
Acer K272HUL - 27in, 1440p, 60hz
Random Dell - 23in, 1080p, 60hz
Random Acer - 23in, 1650x1050, 60hz
Peripherals
Mouse - Corsair Sabre RGB
Keyboard - Corsair K70
Headset - Logitech G35
https://linustechtips.com/topic/577389-issues-with-hyperx-fury-2x4gb/
On 4/6/2016 at 8:08 PM, rheyL said:
when the new rams installed, can you boot till bios?
if yes, you can check there maybe they have diff timings
if not
have you tried the other 2 dimm slots?
I cannot boot til bios unless I'm in single channel.
I have tried the other slots as well. A1 and A2 works. B1 and B2 works.
Currently I'm running in single channel A1 and A2 until I find a solution.
