770. Looking to get either a 1060 or 1070
  1. GLaDOS: i5 6600 EVGA GTX 1070 FE EVGA Z170 Stinger Cooler Master GeminS524 V2 With LTT Noctua NFF12 Corsair Vengeance LPX 2x8 GB 3200 MHz Corsair SF450 850 EVO 500 Gb CableMod Widebeam White LED 60cm 2x Asus VN248H-P, Dell 12" G502 Proteus Core Logitech G610 Orion Cherry Brown Logitech Z506 Sennheiser HD 518 MSX
  2. Lenovo Z40 i5-4200U GT 820M 6 GB RAM 840 EVO 120 GB
  3. Moto X4 G.Skill 32 GB Micro SD Spigen Case Project Fi
https://linustechtips.com/topic/577288-gpu-cooling/#findComment-7550743
3 minutes ago, ripper101 said:
80 degrees in games like GTA 5 and heaven benchmark doesn't go above 77
Celsius? What's the room temp?
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/577288-gpu-cooling/#findComment-7550761
2 minutes ago, ripper101 said:
Yes, and 60*F degrees
That's a bit concerning, make sure your case fans are working and move air through the case. How many do you have?
https://linustechtips.com/topic/577288-gpu-cooling/#findComment-7550781
2... Can you answer my intail question whether it would be better to put an intake or exhaust below it? :)
You can put an exhaust next to it (if there's a vent nearby). But I don't think you should need to.
I assume you've got the Twin Frozr cooler? Did you set a custom fan curve?
https://linustechtips.com/topic/577288-gpu-cooling/#findComment-7550811
No I'm kind of a noise freak and the temps don't mean to much to me or the life time because I don't play those games often enough to make a difference in life time most have been playing cs go and dayz which don't put barely any load on the GPU
https://linustechtips.com/topic/577288-gpu-cooling/#findComment-7550828
25 minutes ago, ripper101 said:
So my GPU is getting hotter than I would have initially liked so I want to put a fan under it to see if my temps improve. Should it be an intake out exhaust?
if its under then set it as intake.
pics of your rig?
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/577288-gpu-cooling/#findComment-7550865
Like @afyeung said, its a 390(X). The triple-slot cooler gives it away.
CPU: Intel Core i7 7820X Cooling: Corsair Hydro Series H110i GTX Mobo: MSI X299 Gaming Pro Carbon AC RAM: Corsair Vengeance LPX DDR4 (3000MHz/16GB 2x8) SSD: 2x Samsung 850 Evo (250/250GB) + Samsung 850 Pro (512GB) GPU: NVidia GeForce GTX 1080 Ti FE (W/ EVGA Hybrid Kit) Case: Corsair Graphite Series 760T (Black) PSU: SeaSonic Platinum Series (860W) Monitor: Acer Predator XB241YU (165Hz / G-Sync) Fan Controller: NZXT Sentry Mix 2 Case Fans: Intake - 2x Noctua NF-A14 iPPC-3000 PWM / Radiator - 2x Noctua NF-A14 iPPC-3000 PWM / Rear Exhaust - 1x Noctua NF-F12 iPPC-3000 PWM
https://linustechtips.com/topic/577288-gpu-cooling/#findComment-7552093
I don't understand why he would tell people he has a 980ti when that's obviously a custom built system so he should know what he put in there. Or somebody cheated him out of a system and sold it to him as a 980ti which is bad. But he seems like he know a thing or two about benchmarking and heaven tells you what card you have. 980ti and 390x are in completely different leagues. 390x is extremely hot, 80c is normal for an aftermarket 390x, not for a aftermarket 980ti which is much more efficient
Current PC: Origin Millennium- i7 5820K @4.0GHz | GTX 980Ti SLI | X99 Deluxe
https://linustechtips.com/topic/577288-gpu-cooling/#findComment-7552114
1 hour ago, ripper101 said:
That is an older picture because I don't feel like moving my computer and getting a picture for it. 390x or 980ti, I have nothing to prove to you.
well, that picture is definitely not yours :/
why would you be complaining about the temperatures when the airflow is open.
/thread
Old Rig
https://linustechtips.com/topic/577288-gpu-cooling/#findComment-7554173
I'll send you it when I get home sense "it's not mine"
*since. And no need for the attitude. Your temps are abnormally high for a 980ti but not a 390x. And if that's an old picture and all you did was replace the card then the airflow is perfect.
https://linustechtips.com/topic/577288-gpu-cooling/#findComment-7555756
No, I don't believe the airflow is perfect because when I place my hand in my system after taking the side panel off the air is pretty hot. So this leads me to believe that the high temperatures are a result of my system not having good airflow to compensate for the heat dissipation by the graphics card just trying to cool it's self with the hot air it just put off of itself. Here is a photo if it makes you feel a little better SINCE (thanks really appreciated the help on that one!!) "the system is not mine"
https://linustechtips.com/topic/577288-gpu-cooling/#findComment-7555784
