So when I'm playing Unturned or Orcs must die Unchained, the fps would suddenly drop from 100+ down to 2 and stays there until I either restart my game or change the core clock +/-1Mhz (or more, as long as I do something about the core clock. it goes straight back up to original FPS)...I can play CS:GO, RS6, GTA 5, JC3 with absolutely no problems what so ever (well there is a slight problem with RS6 but it's not FPS related).
What I've done:
  • ran my CPU and GPU at stock settings, doesn't make a difference...
  • reinstalled my drivers, no difference
  • used my Server's PSU (Only to power the GPU as it's only a 450w PSU...), no difference
Any suggestions?? What I find weird is graphically un-intensive games have the FPS problem while games that require a lot more horses to  run is completely fine...
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
Check your temps, usage, and other stats with MSI Afterburner (while in game). See which graphs get maxed out.
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
I would say the same thing, check your temps. How long ago did you apply thermal paste to your CPU?
Also is anything abnormally dirty? Are all your fans connected/spinning?
Think about the last time you tinkered in your PC, did you leave anything unplugged?
What I've done:
Check your temperatures and CPU/GPU/RAM usage during these games. MSI Afterburner is a good utility for this.
Other systems I've built:
Underload: Furmark-72c, gta5/r6s/heavy games-60c, CS:GO-52c, unturned/OMD:Unchained-48c...so it's defniantly not temps (I OC my 290x with a h75 with afterburner so...you can expect me to check my temps with GPU-z for VRM temps)
Applied thermal paste 4 months ago, Vram usage doesn't go above 2GB (unless I'm playing GTA 5/R6S), RAM usage doesn't go above 9GB (I have 16GB of it :D), both my GPU and CPU is basically pinned at 100% when gaming...
Any other tips?
Just now, DaltonM said:
What % usage is your CPU and GPU at idle?
0-10% (don't expect me to pause my music...)
