Could you technically control the brightness of a bitfenix alchemy strip with a simple fan controller?
My System Specs: (Short list) i7 4770k, GTX 780, many SSD's, a 2 TB HDD(deceased :( ), Corsair 650D. Full list: http://pcpartpicker.com/user/kchriz6097/saved/8dh7YJ
Upgrade Plan: Acquire some Black Noctuas then add 16 or 32GB of 2133MHz memory
https://linustechtips.com/topic/5768-bitfenix-led-brightness-adjustment/
Maybe - people have added resistors to them to lower them. I would assume hooking up to a fan controller would work - once caveate - many controllers are pulse modulating or such. Where there isn't a steady voltage but always changing slightly. Messes up a lot of fans, so not sure how the strip would react.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
I would dare say you would get a breathing effect if it pulsates. LED's do cope well individually with a pulsate not sure how a strip would work. Trial and error in my opinion. i will be getting some strips soon and will hook one up to my RECON fan controller to find out.
