So I recently just built my first loop and my pump seems to be spinning unusually high. It is a ddc pump in an xspc 170 pump res. I know that you cannot control the speed pwm signal as it is a three pin header. How would I go about turning down my pump speed? My motherboard is an x99 sli plus and I can only turn the speed to 50 percent. Is there a product out there that will let me turn this down below that?
Thanks in advance.
https://linustechtips.com/topic/576690-turning-down-pump-speed/
1 minute ago, ELSknutson said:
There should be a place on the pump for speed. I know my pump has 5 speed settings on a small dial on the back
That's not true for every DDC pump.
CPU: Ryzen 3700X VGA: RX 5700 8G RAM: 32GB 3200MT/s DDR4 Motherboard: B450 Aorus Pro
Storage: 2x1TB Crucial P2, 1TB Crucial MX500, 36TB NAS Cooling: Custom Loop 360mm & 280mm
PSU: Super Flower Golden Green HX 650W Case: Phanteks Enthoo Luxe
https://linustechtips.com/topic/576690-turning-down-pump-speed/#findComment-7543979
you need a fan controller which can handle the current the DDC draws to turn it down below 50%
https://linustechtips.com/topic/576690-turning-down-pump-speed/#findComment-7544006
I never said it was.
You said that "There should be a place on the pump for speed".
Whatever, that should work.
https://linustechtips.com/topic/576690-turning-down-pump-speed/#findComment-7544016
