How many watts required
Solved by papapoi,
http://pcpartpicker.com/p/Kx3yD3 estimated wattage upper right corner
http://outervision.com/b/VG72oE another site
500w maybe even a 430w, but better to keep some room in case you decide to upgrade to a better card and/or overclockable cpu since you have a z97 board but not a k-series chip
agree with the evga, g2 if possible, though most evga psu's are fine just dont buy an off brand just cause its cheap
