So there was a massive power outage due to weather today, and after turning my pc on (which was in a surge protector), after opening a program, the machine freezes.The fans stay at a normal pace, but the screen is frozen. I've tried swapping RAM just to see if there was any hope in that seeing as it'd be an easy fix. But not a clue on what it could be.
https://linustechtips.com/topic/575887-computer-freezing-after-power-outage/
Also note, I do not have a recovery disk!
check your drive with crystaldiskinfo
if it shows OK then you have a corrupted OS and you need to do a clean install
2 minutes ago, Wikiforce said:
could possibly be a faulty HDD. By Default, caching for HDD is enabled in WIndows which causes error or corruption if their is a unexpected power loss.
My OS is currently on my SSD and I transferred my Windows OS from the HDD to my SSD with a Samsung Migration tool/kit. Would that cause problems?
Hate to ask, but how would i go about opening it while I can't even open Chrome? I can put it on thumb drive, but is there some sort of work around?
no not really, but if you put the portable version on a USB with some other PC you should be able to run it
if it was anything like all the wind we had here today i unplugged all my  stuff today then the power went  out  and stayed out for 2 hours, sometimes  the power flickers can cause a power surge   and PCs no like a surge. Surge protectors  arent a fail safe,,, i suggest trying to reset your cmos,  the power flickers and on and off nature is not good for electronics.  and pcs are about the worst  at  being a victim to it.
I have heard SSDs are prone to  failures with  a lot of on and off booting  from such a thing, do not take my word for it though.
For the future, a UPS would be a good investment
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
