How to measure battery capacity in a mouse?
orangecat
I've had my G700S for quite some time now and I love it just as much as the day i bought it but I've been wondering if I should change the battery out soon. It has a rechargeable Eneloop battery inside that's rated for about 500 charge cycles and I know for a fact I've recharged this mouse from about dead more than 500 times. It seems to hold a charge just as good as when it was new but I'm curious to know if there's a way to reliably test how well the battery holds a charge without buying some kind of battery tester.
I don't think there's really a unit of measure for that, but I think the g700s runs on a lipo. If the battery is puffed out, lose it in a hurry.
ASU
well, does it still last like it would at the start?
in the end capacity is just a number, its the time you get out of it that you should care about.
runs on an AA in the bottom, he mentioned he has an eneloop in there, and google images are your friend ;)
¯\_(ツ)_/¯
ASU
