Wireless PCIE adaptor for desktop
rasesh
Hey guys I occasionally game & move around a-lot at times and sometimes don't have the leisure to have LAN connection so was deciding to buy myself a pcie wifi adpator.
I was leaning towards purchasing 802.11 AC as they are much faster so I've heard.
I don't have much knowledge at all with all this wifi stuff so needed your help.
Do I really need to spend $80 CAD for a card like this to play games online with smooth experience/no lag?
https://www.amazon.ca/Archer-T9E-Wireless-1300Mbps-Beamforming/dp/B00TQEX7AQ?ie=UTF8&creative=395381&creativeASIN=B00TQEX7AQ&linkCode=df0&ref_=asc_df_B00TQEX7AQ4227747&smid=A3DWYIK6Y9EEQB&tag=shopbotca-20
Any certain one you would suggest?
3 minutes ago, rasesh said:
Does your router support 802.11ac? Because if it doesn't buying an 802.11ac PCIE wireless adaptor would be useless.
That card you linked is good, btw.
Other systems I've built:
I don't know if it does or not.
How do I check?
It's the optik t.v/hdtv router from telus.
So you are saying your WOULD spend $80 on that card?
How do I check?
It's the optical t.v/hdtv router from telus.
It would be listed in the technical specs of your router. Seeing as I'm not from Canada and I've never heard of Telus, I can't find the specs of your router. Can you?
Give me 1min, let me go see & get back to you.
Okay dude I just realized the way my desktop is connected is SO WEIRD that I don't even know if it's right or how it's even working exactly.
I apparently have 2 router's? I don't even know if one is a router or not but here is the current setup I have.
So, all my cables & everything start in my garage to keep the clutter outside of the house.
I mean like the optik wire/t.v cable box etc is outside.
Now on the outside I have the following router i guess?
Model #: T1200H which is connected to the main LAN port coming out of the garage.
http://www.manualslib.com/manual/816410/Actiontec-T1200h.html?page=5#manual
Now upstairs in my room I have another router apparently underneath the desk with the following model #: WCB3000N.
When I was looking at it 2 of the green led lights had 5G and 2G lights and the 2G light was flashing and 5G one was just solid along with other lights on the router.
http://www.actiontec.com/305.html
As you can see I'm very clueless in this department.
A Telus representative came to my house & set this up.
