I've been looking at the Intel Compute stick, not the last gen one but the 2016 model for around the £130 mark. Is there anything out there that's better than that for around the same price? I've seen the Kangaroo mini PC for $99 from new egg but it says out of stock when I change shipping to UK...
DISPLAYS: LG 27UL500 IPS 4k60hz + HDR and LG 27GL650F IPS 1080p 144hz + HDR
LAPTOP: Lenovo Legion 5 CPU: AMD Ryzen 7 5800H GPU: RTX 3070 8GB RAM: 16GB 3200MHz (2x8GB DDR4) STORAGE: 4TB Crucial P3 NVMe SSD + 2TB Samsung 970 evo plus NVMe SSD DISPLAY: 1080p 165hz IPS OS: Windows 11 Pro x64
https://linustechtips.com/topic/573936-mini-pc-required/
How's Amazon UK on price and availability? Some of Newegg's items don't offer overseas shipping from their US selection, and those same items are often not in stock on the UK selection.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/573936-mini-pc-required/#findComment-7516905
If you've previously won the build off please pm me so we can get something worked out.
https://linustechtips.com/topic/573936-mini-pc-required/#findComment-7516911
2 minutes ago, ddbtkd456 said:
Thanks but can't stretch to over £300, £150 would be the max...
https://linustechtips.com/topic/573936-mini-pc-required/#findComment-7516915
3 minutes ago, Moonzy said:
have you considered a NUC? the pc in a stick isnt very powerful
might even stutter while playing youtube vids lol
I'll consider anything as long as its small enough to hide behind a 40 inch 4k TV...
https://linustechtips.com/topic/573936-mini-pc-required/#findComment-7516920
http://www.amazon.co.uk/dp/B010ULA314/ref=psdc_428651031_t2_B00TXZSRC6
https://linustechtips.com/topic/573936-mini-pc-required/#findComment-7516922
Amazon UK don't stock the Kangaroo mini pc - it seems no one in the UK does...
https://linustechtips.com/topic/573936-mini-pc-required/#findComment-7516923
whats your purpose of this computer?
watching vids? browse web? play games? o-o
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/573936-mini-pc-required/#findComment-7516927
1 minute ago, ddbtkd456 said:
Thanks, is that Celeron better than the x5 Z8500?
https://linustechtips.com/topic/573936-mini-pc-required/#findComment-7516929
Vids, web, general word processing etc, no games...
https://linustechtips.com/topic/573936-mini-pc-required/#findComment-7516935
Yes and it should put out less heat from it as well. Feel free to correct me if I am wrong.
https://linustechtips.com/topic/573936-mini-pc-required/#findComment-7516936
try getting a nuc within your budget, im pretty sure it'll perform better than a stick
and gives you more connection for your peripherals too lol
https://linustechtips.com/topic/573936-mini-pc-required/#findComment-7516938
Just now, awesomeness10120 said:
I'd personally wait for that awesome Skull Canyon NUC.
I haven't got awesome skull canyon money >:(>:(>:(
https://linustechtips.com/topic/573936-mini-pc-required/#findComment-7516941
