Nzxt source 530 vs Nzxt phantom 410 vs Nzxt H440
Go to solution Solved by Stuntman12,
If you are worried about air flow specifically, don't go with the H440. I own a H440, I love it. But I keep the ambient temp of my room low and run the 3 front 120mm, rear 140mm and my Kraken x61 280mm cooler running 100%. Its a silence optimized case, not airflow. It has very small intake and exhausts. I read a lot of negative comments about this case getting toasty.
Beyond that, I don't think I can vote between the Source 530 and Phantom 410. I think the Phantom is a little better looking. The Source 530 is a full size case, giving you more space to work with. As for cooling, the Source has a full mesh front and open top, I would guess its the better for airflow. The Phantom does have that side intake though.
1 member has voted
  1. 1. Help me choose best case among these 3
    • Nzxt source 530
    • Nzxt phantom
    • Nzxt H440
      1
I am solely stuck with these 3 mid tower cabinets to choose from ,
Nzxt source 530
Nzxt phantom 410
Nzxt H440
All these 3 cabinets are good but i cant figure out which one is good with airflow. also i will be using 240mm cpu water cooler something like
CORSAIR CPU LIQUID COOLER H110i GTX
COOLER MASTER CPU LIQUID COOLER NEPTON
thanks in advance
Does it have to be a NZXT case? Why not other brands?
Frost | 7700K @ 4.9GHz 1.36v, delidded | Asus DUAL GTX 1060 6GB OC | Corsair LPX 16GB DDR4 2800MHz | Samsung 960 EVO 250GB SSD + Toshiba 1TB HDD + Toshiba 2TB HDD + Samsung 860 EVO 1TB SSD for macOS | Asus PRIME Z270-A | Fractal Design Celsius S24 | Seasonic M12-II 620W PSU | Corsair 400C White | NZXT Hue+
Samsung Galaxy S8 | Stock
Ticwatch E (Black) | Ticwatch Brown Leather Strap
Jumped over to the NZXT website to do a little more research. The Source 530 has more 140mm fan options, can even do a 200mm front intake, but ultimately can hold 9 fans. The Phantom 410 can support 8 fans. Both can support your cooler.
thanks for your info , i will go with nzxt source 530 then , since i am more into air flow not silent case. :)  .
yes you are right but at my place these are the only good cabinets which got my attention at my price point
