Hey guys. Looking into doing two systems with a 3770 and a 5820k, probably without oc at all. Need a fan that could stay silent in the long run as i will be running them (or just one) 24/7.
Currently I'm thinking of one of those:
Noctua NH-D15
Noctua NH-U9B SE2
Scythe SCMG-4000
CRYORIG H7 (CR-H7A)
be quiet! DARK Rock Advanced C1
be quiet Dark Rock Pro 3
any thoughts?
first post, yay
https://linustechtips.com/topic/573753-cpu-coolers-for-247-operation/
Noctua NH-D15 It has like 7 year warranty so you know it won't break anytime soon.
Magical Pineapples
Noctua NH-D15
Noctua NH-U9B SE2
Scythe SCMG-4000
CRYORIG H7 (CR-H7A)
any thoughts?
first post, yay
NH-D15
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
Noctua NH-D15
Noctua NH-U9B SE2
Scythe SCMG-4000
CRYORIG H7 (CR-H7A)
any thoughts?
first post, yay
Dark rock pro 3 but take off the fan so theres no failure because you don't want water or fans getting loud. Plus its a good passive heastsink!
CPU: Intel Core i9 9900K | Ram: 32GB Corsair LPX 3200 DDR4 | Asus Maximus XI Hero Z390 | GPU: EVGA RTX2080 XC | 960 EVO Samsung 500GB M.2 | 850 EVO Samsung 250GB M.2 | Samsung 1TB QVO SSD | 1TB HDD WD Blue
refer to my post about fans, some of my collection is older than the average LTT forum member, with zero maintenance required.
fans last longer than you think. and its better to have the fan there and the system warning you about failure when it comes down to it than no fan at all.
(PS: fans are hotswappable -- if you can reach the headers)
