2 minutes ago, vinnyerrero said:
Hi guys, I'm planning to build a X99 Deluxe + 5820K + 980 Ti build in the next months, but my desk has a depth of only 18in
What ATX compatible cases do you recommend?
Fractal R5
https://linustechtips.com/topic/573592-best-low-depth-atx-case/#findComment-7513223
Define S FTW
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
https://linustechtips.com/topic/573592-best-low-depth-atx-case/#findComment-7513303
4 minutes ago, ELSknutson said:
Dimensions & Weight
Dimensions (H x W x D)
18.19" x 9.13" x 20.91" with feet/screws/protrusions
17.76" x 9.13" x 20.51"
im pretty sure the case is longer than it is higher
https://linustechtips.com/topic/573592-best-low-depth-atx-case/#findComment-7513457
31 minutes ago, Aytex said:
LxWxH
20.47" x 9.09" x 17.76"
Thats Length....
Depth is hight, which is 17.76"
That makes sense
Depth equals hight so if a lake is 500 feet deep it is 500 feet high
so if a table is 18 inches deep then it is 18 inches form the floor to the top of the desk then right? Well actually the depth of a desk is measured from front to back. Which is the length.
so the detentions of the case are  20.47 inches long x  9.09 inches wide and 17.76 inches high
https://linustechtips.com/topic/573592-best-low-depth-atx-case/#findComment-7513539
7 minutes ago, ELSknutson said:
That makes sense
Depth equals hight so if a lake is 500 feet deep is is 500 fee high
so if a table is 18 inches deep then it is 18 inches form the floor to the top of the desk then right? Well actually the depth of a desk is measured from from to back. Which is the length.
lol
https://linustechtips.com/topic/573592-best-low-depth-atx-case/#findComment-7513574
  • 7 months later...
