Hi Guys/Ladies on LTT forum!
After watching almost tons of LTT/NCIX Tech Tip videos on youtube, I finally appeal to the pros on the forum for my first ever PC Build! xD
Myself:
  1. Never really had any experience with full PC building (I had experience with upgrade module like pull out a part and plug in a new part)
  2. I consider myself somewhat average on PC knowledge (I know what a ram does and what does PCI means.. I think B|)
1. Budget & Location
Budget: AUD$5000 incl peripherals (Do note Australia has ridiculous % of GST and almost every tech stuff is more expensive than the US of A & Canada)
2. Aim/Reason for Build
Well folks, I am currently running a 5 years old Alienware M14x R2, Second Generation Intel i7-2670QM @ 2.2 Ghz, 8gb of Ram, Nvdia 3gb GT 555M (yes that right GT.. omg Leslie does those things still exists?! :ph34r:), so I am missing out on lots of big title like The Division, Witcher 3, GTA V, Rainbow Siege (etc etc).
So in simple, I am wanting to build a PC for gaming (proper 60fps smoothness) and hopefully to be a VR ready rig.
PS: Will be attempting to learn how to Overclock this rig too!
3. Monitors
Currently just wanting 1 monitor but might consider dual to triple display in the future.
I am planning to use this monitor:  Acer XB280HK 28in 4K G-Sync Widescreen Gaming Monitor
Hopefully will be gaming on at least 1440p, the reason I go for this monitor is because of its value, G-Sync and 4K resolution.
4. Peripherals/Parts
Well this is going to be a RazerTM theme build so the peripherals will be as below:
PC Itself*:
Estimated Cost: AUD$3000
Peripherals**:
* I will need an expert/pro to check if all these part will fit with each other/ or if there is any room for improvement/ better parts you recommend.
** I know is a full on Razer theme (and I know some people probably think I am better of with Cosair Keyboard/parts etc etc, but I am trying to stick to a theme on the peripherals, the PC itself is pretty much what I think is within budget.
Summary:
In simple I just want an second opinion before I go ahead and click the order button and if any kind person would walk me thru if they recommend a first timer building this PC.
Constructive feedback appreciated!
Will keep you guys posted!
Leslie
https://linustechtips.com/topic/572928-first-time-pc-building-pro-tips-needed/
Sticking to a theme dosen't do you good, only asthetics
Sound quality and just build quality it will be absolute shiet
Get a i5 6600k if you don't video edit
For watercooling AiO's I would go for X61 or a h100i GTX
Everything else loosk good
I would get X99 if youre spending this much money, Direct X 12 is going to want cores
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
Sounds like you already got it all together.
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
Myself:
3. Monitors
PC Itself*:
Peripherals**:
Summary:
In simple I just want an second opinion before I go ahead and click the order button (Total of AUD$ 5047) and if any kind person would walk me thru if they recommend a first timer building this PC.
Leslie
1. http://au.pcpartpicker.com/
2. I'm going to recommend against those headphones
3. I'll design you a build real quick, just for comparison purposes.
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
Razer peripherals are fine, but their headsets please avoid em especially the kraken.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
Myself:
3. Monitors
PC Itself*:
Peripherals**:
Summary:
Leslie
PCPartPicker part list: http://au.pcpartpicker.com/p/wZzqK8
Price breakdown by merchant: http://au.pcpartpicker.com/p/wZzqK8/by_merchant/
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($566.00 @ Mwave Australia)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($195.00 @ CPL Online)
Motherboard: MSI X99A SLI PLUS ATX LGA2011-3 Motherboard  ($360.50 @ Centre Com)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  ($124.00 @ CPL Online)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($228.00 @ CPL Online)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($69.00 @ Centre Com)
Video Card: EVGA GeForce GTX 980 Ti 6GB HYBRID Video Card (2-Way SLI)  ($1249.00 @ CPL Online)
Case: NZXT H440 Designed by Razer™ ATX Mid Tower Case  ($219.00 @ CPL Online)
Power Supply: XFX ProSeries 1050W 80+ Gold Certified Fully-Modular ATX Power Supply  ($219.00 @ PCCaseGear)
Monitor: BenQ GW2765HT 60Hz 27.0" Monitor  ($516.50 @ Centre Com)
Keyboard: Razer BlackWidow Chroma Wired Gaming Keyboard
Mouse: Razer DeathAdder Chroma Wired Optical Mouse  ($65.00 @ Mwave Australia)
Total: $5060.00
Generated by PCPartPicker 2016-03-29 01:42 AEDT+1100
Solitaire.
