HWMonitor reported a HUGE temperature
Go to solution Solved by Josephdalepi,
1 minute ago, Nightfallen said:
Hi guys,
I've been leaving HWMonitor to run while I was playing some games on my rig and I've noticed that TMPIN4 sensor reported a HUGE temperature ~146 degrees Celsius.
What's that temperature? What's been affected?
Thanks in advance!
Alex.
Screenshot attached here so I won't ruin the page format:
  Reveal hidden contents
YApw89n.png?1
glitch
mobo sensors can be funny sometimes
check my profile picture
Hi guys,
Thanks in advance!
Alex.
YApw89n.png?1
https://linustechtips.com/topic/570891-hwmonitor-reported-a-huge-temperature/
Hi guys,
Thanks in advance!
Alex.
YApw89n.png?1
glitch
7 minutes ago, Nightfallen said:
Thanks guys, I got scared as hell :D
yea pretty sure your pc would have shut down nevermind your component melting or on fire by the time you even saw that degrees on hwmonitor :), as others have said above its a glitch in the sensors
[CPU] Ryzen 5 3600x [Cooling] be quiet! Dark Rock Pro 4 [Mobo] B450 Tomahawk Max [RAM] 16GB (2X8) Corsair Vengeance LPX 3000MHz [GPU] RTX 2070 Super Gaming X Trio [PSU] XFX XTR 750W [Case] Fractal Design Define R5 Windowed
Interesting temperature though... I would have expected 127 °C to be honest
2 hours ago, Nightfallen said:
Hi guys,
Thanks in advance!
Alex.
YApw89n.png?1
If you think that's crazy, you would be amazed to see Heaven Benchmark reporting my GPU temp as 300million C.
That's literally hot enough to destroy the entire earth in less than a second.
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
