I have a Corsair H100i GTX in my case as an exhaust, going bottom to top: fans,case,radiator.
I was considering getting a new case and I was wondering if mounting the rad to the front of any new case as an intake would provide better temps than having it on top as an exhaust? I have an aftermarket cooled GTX 970 FTW so it does get warm inside when under load so I think exhaust is making the cpu temps a little warmer than if it was an intake at the front.
Can anyone confirm or deny this, thank you
https://linustechtips.com/topic/570763-better-aio-positions/
maybe like one or two degrees
the best reason for mounting in the front is it helps trap microbubbles from going around continuously which makes the AiO quieter
https://linustechtips.com/topic/570763-better-aio-positions/#findComment-7486228
Alright I guess It doesn't matter if the case I get can support the AIO on top or the front, thank you! Although my pump runs fine thankfully and I dont hear anything from it other than the fans, one has a buzzing sound so I'll replace it with a Thermaltake Riing sp fan :D was hoping this would have been answered in the recent video but it got me wondering.
https://linustechtips.com/topic/570763-better-aio-positions/#findComment-7486247
