Is there any way that you can get the audio off of an hdmi video signal to move it into a receiver. So that isnt the crappy speakers built into a tv I am stuck listening to.
This is my short return form a long hiatus due to work and school.
Thanks fir the help everyone
                     Lou
https://linustechtips.com/topic/57053-hdmi-audio-removal/
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/57053-hdmi-audio-removal/#findComment-772024
anything other then a switch that has that feature and still uses hdmi?
Not that I know of.
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
https://linustechtips.com/topic/57053-hdmi-audio-removal/#findComment-772982
you, sir, want a basic HDMI receiver connected to speakers:
http://is.gd/GrZrJV
signal - HDMI -> receiver -> speaker array.  Then the "TV out" HDMI to the TV
"Pardon my French but this is just about the most ignorant blanket statement I've ever read. And though this is the internet, I'm not even exaggerating."
https://linustechtips.com/topic/57053-hdmi-audio-removal/#findComment-773068
