Freesync 165Hz Monitor?
rcarlos243
Is there any 1440P 165Hz monitor released / announced?
So far I only heard about Acer XB1 Gsync and Asus PG279Q to be 1440P 165Hz IPS.
I am also looking currently at Asus MG279Q 1440P 144Hz Freesync and I am wondering if that monitor can be manually overclocked to 165Hz without frame skipping.
Yeah, we're all just a bunch of idiots experiencing nothing more than the placebo effect.
The difference between 144 and 165 is very minimal, I don't really know why you would do that anyway.
Current Build: Core i7 4790k @ 4.6, Asus Maximus VII Hero, Corsair Vengeance Pro 2400mhz 8gb (2x4gb), GTX 980ti, NZXT Kraken X61, Fractal Define R5  EVGA Supernova B2 850w, Some 300gb hard drive.
http://pcpartpicker.com/p/W7CNrH
not true especially if you have used a high end CRT.
Even a strobe backlight 144Hz is not as clear as a CRT
Do the math.
With 144Hz you will get a new image every 6,95ms (1000/144) and with 165Hz you will get one every 6,06ms. You gotta be some sort of super human to notice a difference. We are talking about not even 1ms...
I think 144Hz is perfectly fine.
CPU: i7-4770k (LM modded) - MB: GA-Z87X-UD3H - RAM: HyperX, 16GB 1866MHz - GPU: Palit GTX 980Ti Super - Storage: 1TB HDD + 500GB/120GB SSD (850 Evo/840) - Monitor: Predator XB271HU - PSU: 700W BeQuiet 80+ Gold
3 minutes ago, Mecami said:
Do the math.
every tenth counts considering CRT have 1ms motion blur display persistence and strobe backlight LCD has about 2ms.
Why do you mention CRTs all the time? Am I missing something?
I need S340. But more Define S'ish
I don't think there is one with FreeSync, probably easier to just get a Nvidia graphics card :D
On 3/24/2016 at 3:24 AM, Overkilled said:
I've got the mg278q and it doesn't oc past 148
isn't mg278q different from mg279q
The 279q is ips slower response time 278q is tn but faster response time
  • 1 month later...
the mg279q will only offer up to 90 hz while Freesync in enabled. (Sadly..)
I guess that is caused by what was mentioned..:
However.. there IS coming a Freesync monitor with 165hz (that is compatible with Freesync all the way up to 165hz). The ViewSonic XG2703 - one of XG03 series, releasing in 94 days ...
http://gaming.viewsonic.com/XG2703/
Price not confirmed i think. One review site mentioned 700-900 USD, another mentioned 1200 USD (I think 1200 USD is most likely).
the mg279q freesync range is compatible up to 144hz.
