I think I did good with the cable management inside of a case that allows for 0 cable managment
https://linustechtips.com/topic/569781-cable-management/
You can't really do much cable management with that case but just try to tuck most of the cable into the drive bays because the cables aren't really blocking airflow
That video shows a bit about it but it seems that cables dont make the temperatures rocket
  • CPU: AMD athlon  860k
  • Motherboard: Gigabyte F2A58M-HD2
  • RAM:2x4gb HyperX Fury
  • GPU: XFX R9 380 4gb
  • Case: NXZT S340
  • PSU: EVGA 650G
  • Display: BenQ GL2460HM
  • Cooling: Hyper 212 Evo
  • Keyboard: Corsair k60
  • Mouse: Steelseries Rival 300 (white
  • Sound Logitech g430
  • Operating System: Windows 10 64bit
https://linustechtips.com/topic/569781-cable-management/#findComment-7476479
Naw, you did okay with it. I think I did rather well in my case that has barely enough room for my GTX 480.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/569781-cable-management/#findComment-7476485
Pretty sure you can untangle a couple of cables and tug them away.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/569781-cable-management/#findComment-7476534
