Hey guys basically I'm trying to fix my friends computer his got a really old one so I told him to buy a new cpu and convert to a ssd, he has a amd 145 so he bought a new one and he bought a Kington ssd  because he had a really old hard drive and thought it would speed up boot time, basically we have installed Windows and it's been really slow the mouse is laggy but it's a wierd type of lag, I don't know what to do when I built my computer it didn't have this issue cheers guys ?
https://linustechtips.com/topic/569374-help-computer-issue/
What are his current system specs? Is the HDD still plugged in? If so, make sure the SSD is the boot device.
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/569374-help-computer-issue/#findComment-7472489
So its 4gb ram 145 amd cpu brand new ssd 120gb old motherboard gigabyte  and that's it really we threw away old hhd and cpu
https://linustechtips.com/topic/569374-help-computer-issue/#findComment-7472505
Err... you got this CPU?
In that case, I'm not surprised. It's a single core AMD processor, that's the performance I'd expect from it.
https://linustechtips.com/topic/569374-help-computer-issue/#findComment-7472519
With those other spec I would have upgraded the base first. Sry to tell you that.
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/569374-help-computer-issue/#findComment-7472535
2 minutes ago, donboki said:
No but the old CPU didn't cause the mouse to be laggy that's what I'm saying
What was the old CPU?
https://linustechtips.com/topic/569374-help-computer-issue/#findComment-7472541
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
https://linustechtips.com/topic/569374-help-computer-issue/#findComment-7472559
8 minutes ago, donboki said:
Is was the 145 amd
Wait, you replaced the old CPU with the same CPU? In that case, it should preform the same, but you really should get a dual or quad core CPU.
RedWulf suggested some good ones above.
https://linustechtips.com/topic/569374-help-computer-issue/#findComment-7472593
Oh my I know I spent 1.7k on my PC but I'm asking with this is there any drivers that need installing or something cause for some reason my friend uses the onscreen keyboard and as soon as I open that it seems to lag and before it didn't, the cooking is alright I put enough thermal paste on it and the fan is stock
https://linustechtips.com/topic/569374-help-computer-issue/#findComment-7472635
12 minutes ago, imreloadin said:
When you installed the SSD did you just clone the old OS onto it? If so I'd suggest doing a fresh install.
What OS is he using anyway?
Nah I think what has happened is that the bios was set to 32 bit and the Windows was 64 :/
https://linustechtips.com/topic/569374-help-computer-issue/#findComment-7472713
Weird, I know that CPU is 64bit. I guess I wasn't aware that you had to set which version you used in the BIOS.
I also didn't think it would even boot if that was the case lol.
https://linustechtips.com/topic/569374-help-computer-issue/#findComment-7472739
Also forgot to install mobo disk silly me and there's no windows programs wtf
https://linustechtips.com/topic/569374-help-computer-issue/#findComment-7473173
