he can maybe use his current HDD and optical drive. and what games will he be playing? 500 may not cut it if he aims for latest titles and high to max settings.
| i5 3570 | Palit GTX 680 jetsream | Gigabyte Z77x-ud3h | Corsair Vengeance 2x4 1600mhz | WD Caviar Black  1TB | Corsair TX 650m | Coolemaster Hyper212 X | NZXT Pantom 410 | Asus VS239 | Logitech G400s |
Click here to learn how to troll
https://linustechtips.com/topic/56934-need-help-with-build/#findComment-770133
a mini pc would work fine.
 [spoiler=CORMAC]CPU:Intel celeron 1.6ghz RAM:Kingston 400mhz 1.99gb MOBO:MSI G31TM-P21 GPU:Will add one later on! CASE:local ROUTER D-Link 2750U, D-LINK 2730U MOUSE:HP,DELL,ViP KEYBOARD: v7 SPEAKERS:Creative 245  MONITOR:AOC E970Sw HEADSET: Sony MDRx05s UPS:conex ups avr 500va PSU:idk OD:Samsung super writemaster STORAGE:80 gb seagate+ Seagate 1TB OS:Windows xp sp3 themed to Windows 7 + Linux |Rest all pc in my house will be updated from time-time
COMING SOON
https://linustechtips.com/topic/56934-need-help-with-build/#findComment-770144
He is planning on using current hdd and such. He wants to play bf4.not on max though still I know this is a tight budget
Max for 500 sounds impossible
Will he be using the same monitor ?
What reselution ?
If your grave doesn't say "rest in peace" on it You are automatically drafted into the skeleton war.
https://linustechtips.com/topic/56934-need-help-with-build/#findComment-770172
Resolution is important. I don't think he will be able to meet the $500 budget restriction for bf4 at 1080p but definitely can for just a little bit over that.  Does he already have his OS?
| Currently no gaming rig | Dell XPS 13 (9343) |
| Samsung Galaxy Note5 | Gear VR | Nvidia Shield Tab | Xbox One |
https://linustechtips.com/topic/56934-need-help-with-build/#findComment-770187
http://pcpartpicker.com/p/1EoDb
should play bf4 at around high settings. if  he needs a new hdd then downgrade to a 7850 and a 1tb caviar blue.
Cpu: Intel core i5 4570 gpu: gtx 770 case: cm storm enforcer psu: xfx pro 550w motherboard: asus b85m-g ssd: samsung 120gb hdd: wd caviar blue 1tb ram: kingston hyperx blu 8gb 1600mhz mouse: razer deathadder monitor: some decent samsung 19" keyboard: CM Storm TK Blue
https://linustechtips.com/topic/56934-need-help-with-build/#findComment-770219
This^
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
https://linustechtips.com/topic/56934-need-help-with-build/#findComment-770390
Is he going to be including peripherals and/or a  monitor and OS in that?
CPU - AMD FX-6300 3.5GHz 6-Core Processor
MOBO - MSI 760GM-P34(FX) Micro ATX AM3+ Motherboard
2 choices (1 if he isnt gonna upgrade aka SLI crossfire and 1 if he does (top is one if he doesnt)
MOBO - MSI 970A-G43 ATX AM3+ Motherboard
MEMORY - GeIL Enhance CORSA 8GB (2 x 4GB) DDR3-1333 Memory
STORAGE - Seagate Momentus 750GB 2.5" 7200RPM Internal Hard Drive
GPU - Sapphire Radeon HD 7950 3GB Video Card
PSU - Corsair CX 430W 80 PLUS Bronze Certified ATX12V Power Supply
Final price - $509
AMD FX 6300 | ASUS M5A97 R2.0 ATX AM3+ | HITACHI ULTRASTAR 1TB 7200RPM HDD | XFX RADEON HD 7950 3GB | 8GB DDR3-1600 MUSHKIN BLACKLINE | OCZ ZT 550W 80+ BRONZE PSU | ZALMAN Z5 PLUS CASE | LITE-ON iHDS118-04 DVD/CD DRIVE | BENQ GW2255 21.5" MONITOR
https://linustechtips.com/topic/56934-need-help-with-build/#findComment-771597
I'd get the one that @ComputerNoob suggested, but:
1. Skip the CPU cooler
2. Got at least 550W PSU and the cheapest 7950 you can find, preferably not stock
OK I just looked it up:
1. Keep the cooler
2. Get OCZ Fatal1ty 550W
3. Get Powercolor HD7950
Price is $499.91 ;)
My rig: CPU: Intel core i5 4670K MoBo: MSI Z87-G45 Gaming RAM: Kingston HyperX Beast 2x4GB 1600mhz CL9 GPU: EVGA GTX780 SC ACX SSD: ADATA Premier Pro SP900 256GBHDD: Western Digital RED 2TB PSU: FSP Aurum CM 750W Case: Cooler Master HAF XM OS: Windows 8 Pro
My Build log, the Snowbird (heavy WIP): http://linustechtips.com/main/topic/188011-snowbird-by-lachy/?hl=snowbird
https://linustechtips.com/topic/56934-need-help-with-build/#findComment-771696
Mind listing all the specs of what he has so far?
https://linustechtips.com/topic/56934-need-help-with-build/#findComment-772013
gtx 9500gt 512mb.
athlon x 2 250.
amd mobo
1tb hdd
win7
5 gigs of ddr2
400watt  psu
In that case,
Edits: http://pcpartpicker.com/p/1EyOI
https://linustechtips.com/topic/56934-need-help-with-build/#findComment-772246
In that case,
Why 1x8 gb of memory? And why get rid of the cpu cooler? I agree with the video card, did not see that the 7870 ghz was cheaper then the regular one. Oh and yea, i didn't see that that was an old motherboard without usb 3.0.
https://linustechtips.com/topic/56934-need-help-with-build/#findComment-774813
1. Keep the cooler
Price is $499.91 ;)
get this motherboard instead:
http://pcpartpicker.com/part/asus-motherboard-m5a78lmusb3
this one has usb 3.0 and is newer i think.
https://linustechtips.com/topic/56934-need-help-with-build/#findComment-774815
Because it's cheaper and fits the budget without having to rely on rebates.
https://linustechtips.com/topic/56934-need-help-with-build/#findComment-774818
