8 minutes ago, GeorgeKellow said:
I want to replace the side panel windows with some glass
What type of glass should I use?
Would It be expensive to do?
Last I checked, the Phanteks Enthoo Pro M comes with a high-quality transparent plastic window that doesn't easily give way to scratches.
Unless you want a tint or something, why do you want to replace the acrylic window with glass?
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
Its got a few noticeable scratches on it :(
Well, that's a shame.
I'll admit that I know as much about glass as I know about the mating habits of Komodo Dragons- precisely nothing. However, NVidia has a series of case mod videos called 'GeForce Garage'- one of the few helpful things they've created. In one of their videos (here), they cut a window into an old Antec 900 series case. They might have pointers on what kind of plastic or glass to use.
I have a guide here under Window Mod which covers both cutting and installation of glass, but in general you can use regular window glass as long as you are careful.
Edited by W-L
