ive just bout x2 of these processors will these work in my mother board I not know if they are LGA2011 V1, LGA 2011V2 OR LGA 2011 V3 at the time of buying them I didn't no that their was 3 different versions of the same soccet
the Z10PE-D8 WS motherboard says its an LGA 2011 V3 SOCCET will this be compatible with older LGA 2011 CPU'S
Intel Xeon E5-2670 2.6 GHz 8-Core L3 20M Processor C1 SR0H8 LGA 2011 115W CPU
Brand: Intel Clock Speed: 2.6GHz
MPN: SR0H8 L2 Cache: 8 x 256KB
Number of Cores: 8 L3 Cache: 20MB
Socket Type: LGA 2011/Socket R Cooling Component(s) Included: None/Processor Only
EAN:
Does not apply
Z10PE-D8 WS
https://linustechtips.com/topic/568352-help-plz/
5 minutes ago, nerdnooby said:
what idiot at intel thourt it was a good idea to label sockets that arnt backward compatible the same thing and how does this guy still have a job he should be fired just for suggesting it
Its not idiotic at all, -3 socket is the same dimensions and pin pitch, the difference is an upgrade to allow for DDR4 RAM support. It was a minor upgrade to an existing socket... Dont take out your lack of investigation before buying out on something thats perfectly reasonable.
Quack 🦆
https://linustechtips.com/topic/568352-help-plz/#findComment-7462126
Thats X79 buy a Socket-R board
basically if you had 1 cpu buy a X79 Sabertooth
Since you have 2 find a dual slot LGA 2011 Board (Socket-R)
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
https://linustechtips.com/topic/568352-help-plz/#findComment-7462134
That board should work to
https://linustechtips.com/topic/568352-help-plz/#findComment-7462142
