Hi, basically, need help and advice on a audio setup. budget for total is around $700-800. Not a friking crazy audiophile, dude who just wants to heard good vibes.
Few passive speakers in mind: Boston Acoustics A26, Wharf 10.2, Paradigm A2, Audioengine P4 Monitor speakers MR2
any other good speakers for around $450 or even just great speakers under that price?
For AMP/DAC/what ever,
How should I use the Schiit modi and/or the SchiitMagni? Or are they both really only for headphones....They looked so sexy, but I don't think I can use them cuz I got speakers right?
But I was looking at the audioengine N22 which looks sleek and the price is fine. Why are amps so expensive?!?! That looks like my only viable option. I forgot about the Denon AVR-1513, higher price, more features, but looks less sleek and a bit complicated...
For sound cards, a asus or a creative?
bottom line
1. best sounding speaker out of the 5? or do you have a good one for under $450 that you recommend? (for the wharfs, I read you really need an amazing amp to to show its best so that may take it out of the list)
2. Amps? For under $250-300 and works well with a speaker that you recommend/the ones I listed? like the N22,
3. Sound cards under $200? I read that creative and asus are the best one.
Thanks!
Selling my parts of my 900D rig for a jacked up Ncase M1. PM me for offers if interested (will take some reasonable-low offers because I'm desperate).
Parts that I'm selling: 900D (1 slot cover broken for stealth DVD drive mod) | Asus Z87 Deluxe | Cooler Master 212 Evo | Corsair 4x2GB black ram @1600mhz | EVGA 1000G2 PSU (2 cables with missing heat shrink) | DVD drive | HP membrane keyboard | Ducky Shine 3 YOTS in blue switches (warranty sticker broken)
https://linustechtips.com/topic/56803-entry-level-audio-setup/
i got myself a harman kardon 980 and a pair of white magnat vector 205 when both were quite expensive... never regreted it. great for listening to music and even gaming sometimes.
This setup saves every party :D I do not know any of the named brands, maybe they just aren't as big in germany as where you live but i wouldn't buy something i've never heared of
-edit: ok i just looked up those speakers and understand why i've never heard of those brands: im not into monitoring speakers :P
        wow... pretty empty here...
https://linustechtips.com/topic/56803-entry-level-audio-setup/#findComment-767935
I'd get a good amp with optical in, forget all the surround features and stuff if you are only interested in stereo. run optical from your motherboard or basic (real basic) soundcard if you need to and spend the rest on speakers, the speakers are the weakest link in any system so you need to spend as much there as possible.
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
https://linustechtips.com/topic/56803-entry-level-audio-setup/#findComment-769768
I bought a Onkyo TX-SR506 Reciever/AMP and a full 5.1 bundle of Warfedale 9.0 diamondbacks for around £900 4 years ago and i am so glad i did. Sound it outputs wows me every time i put a bluray or cd on.
I just had a quick google and you can get the Warfedale for around £40 for a PAIR!
If you have a smallish size room like me (3.5m) i would recommend them anthing larger maybe the 9.1's
https://linustechtips.com/topic/56803-entry-level-audio-setup/#findComment-779774
Dayton Audio speakers and Lepai 2020a+ Amp
CPU: Ryzen 5 3600 | Cooler: Stock | RAM: 16GB Hyper Fury X RGB | GPU: RTX 2080 Super FTW3 | Motherboard: Gigabyte Aorus Elite| PSU: Corsair RM850x
Storage: WD SN750 500GB / 850 500GB Samsung Evo /  | CASE: 570X | Display: Dell u2414h  | KEYBOARD: Corsair K70 | MOUSE: Corsair M65
https://linustechtips.com/topic/56803-entry-level-audio-setup/#findComment-781188
https://linustechtips.com/topic/56803-entry-level-audio-setup/#findComment-785288
I always thought of entry level as under about $500. Talking about amps, speakers, and soundcards isn't entry level :P
But I am somewhat working class poor so I have no room to speak.
I get 60 frames at 1080p on a dual core APU. Ask me how.
AMD FX 8350 CPU / R9 280X GPU / Asus M5A97 LE R 2.0 motherboard / 8GB Kingston HyperX Blue 1600 RAM / 128G OCZ Vertex 4 SSD / 256G Crucial SSD / 2T WD Black HDD / 1T Seagate Barracude HDD / Antec Earthwatts 650W PSU / Coolermaster HAF 922 Case
https://linustechtips.com/topic/56803-entry-level-audio-setup/#findComment-789097
  • 2 weeks later...
I just picked up a pair of Audioengine A5+ speakers. I quite like them. They are large though.
CPU AMD Ryzen 2700 X / Motherboard  / RAM 4 x 4GB  / GPU Zotac 1080Ti Amp Edition / Case Fractal Design Meshify C / Storage Samsung 850 PRO / 1TB WD Black & 2TB WD Green / PSU / Cooling Noctua / Keyboard Ducky Shine 2 / Mouse Logitech G700 / Sound O2 Amp/DAC & Audioengine A5+ speakers
https://linustechtips.com/topic/56803-entry-level-audio-setup/#findComment-847085
