Hello all,
So I have ran a TF2 server for a while now, but today, srcds.exe wont load up. I've tried everything. Rebooting, reinstalling, running from CMD. It just wont work. The server is running on Windows Home Server 2011
Any help is appreciated
You are on a need to know basis, and you don't need to know.
https://linustechtips.com/topic/567789-srcdsexe-not-opening/
Quote
echo off
cls
echo Protecting srcds from crashes...
echo If you want to close srcds and this script, close the srcds window and type Y depending on your language followed by Enter.
title srcds.com Watchdog
:srcds
echo (%time%) srcds started.
start /wait srcds.exe -console -game cstrike +map de_dust +maxplayers 16
echo (%time%) WARNING: srcds closed or crashed, restarting.
goto srcds
Replace cstrike with whatever tf2's codename is.
Quote
My native language is C++
https://linustechtips.com/topic/567789-srcdsexe-not-opening/#findComment-7457047
5 minutes ago, dukethedj said:
Why I have never heard of it. Could you provide an example?
This is my .bat script I use to boot up (excuse the stuff at the beginning, just lets me type in the map I want to boot in to)
set /p MAP=Enter map:
CLS
"X:\TF2\steamapps\common\Team Fortress 2 Dedicated Server\srcds.exe" -console -game tf +map %MAP% +maxplayers 32
PAUSE
It's just essentially launching srcds.exe and giving it some parameters.
I feel like you have a slightly bigger problem than this, though, if you're getting errors like that.
Refer here to see this a bit more in depth:
https://wiki.teamfortress.com/wiki/Windows_dedicated_server#Create_a_file_to_run_the_server
https://linustechtips.com/topic/567789-srcdsexe-not-opening/#findComment-7457050
CLS
PAUSE
So the server looks like its loaded, but I can't connect to it now. I tried the local server ip and public ip to connect. Both failed. I have the same exact settings that I've had since I've started the server originally.
https://linustechtips.com/topic/567789-srcdsexe-not-opening/#findComment-7457075
What were you using to boot it before? You may have had a parameter set for your IP (as mentioned in the article I linked)
https://linustechtips.com/topic/567789-srcdsexe-not-opening/#findComment-7457082
So here is the whole code that has worked before
CLS
"C:\GameServer\TF2\srcds.exe" -console -game tf +map achievement_idle +maxplayers 12 +sv_lan 0 +mp_idlekickmethod 0 +sv_lan 0 +ip 0.0.0.0
PAUSE
I will try to remove +ip 0.0.0.0
https://linustechtips.com/topic/567789-srcdsexe-not-opening/#findComment-7457087
CLS
PAUSE
Looks good but remove the second instance of sv_lan 0
https://linustechtips.com/topic/567789-srcdsexe-not-opening/#findComment-7457090
Just now, cdsboy2000 said:
Try typing "connect localhost" in console if it doesn't show up in the LAN section of your servers list.
That does nothing for me. I'm trying to connect to another computer on the network. Probably should have said that before.
https://linustechtips.com/topic/567789-srcdsexe-not-opening/#findComment-7457231
Try using the connect command with their internal IP in the network (ex: 192.168.1.8)
https://linustechtips.com/topic/567789-srcdsexe-not-opening/#findComment-7457351
19 hours ago, dukethedj said:
I did. It is still not working...
Do you have any other network settings that may be conflicting with that? Otherwise I would say just make a fresh server with the wiki recommended launch command exactly and see if it works. I honestly have no idea at this point.
https://linustechtips.com/topic/567789-srcdsexe-not-opening/#findComment-7461649
